chow
help help emu emu
i am using a mm speakers which use a stereo mini plug cable to soundcard
but after upgrading to emu0404, i bought a converter to connect the stereo mini plug from my speakers to the 1/4 output(analog breakout cable) (i try the left and right outputs )
how come no sound? or i am doing the correct thing?
Did you install the DSP? Or just drivers? You will need to install the dsp to play music...
Edited by mmatrix
thanks guys need a customised breakout cable
i got a mm speakers using 1x stereo mini plug cable, so getting mono sound now, need to split the signal, is it better to make a 1/4 output breakout cable and buy a stereo mini female split to connect the mini plug cable both left and right speakers?
or simply change the mini plug cable to a dual split wires?
need a quotation:
-change a 22 gauge speaker wire to with RCA terminals to a better 1
-breakout cable, pls advise
9383 3694
__________________
