Stereo_Electronics
Goldring GX200
Latest model from Goldring. Demo piece available, stocks available next week.
The GX200 is a premium upgrade product where high quality materials and stunning audio performance combine
The earphones are perfectly suited for use with home entertainment systems or on the move with a portable audio or video player
Can be enjoyed while exercising - the silicone buds or Complyâ„¢ tips ensure an optimum fit is maintained at all times
The carry case is ideal when you’re on the move, as it provides a safe storage solution for the earphones and may be carried easily in a pocket or bag
The patented sound isolation technology offered by the Complyâ„¢ canal tips significantly reduces outside noise - perfect for use when travelling
Accessories included:
Bespoke carry case with integrated cable winder and external mesh pocket for protective storage of an MP3 player.
GX200 Earphones Features
Unique design with striking aesthetics
Constructed from high quality materials which include satin plated die-cast zinc bodies and machined aluminium jack plug
Triple method cable management system which allows the user to wear the earphones one of three ways; symmetric, asymmetric or necklace
Flexible, high performance cable with OFC conductors & interference shielding
Supplied with patented Complyâ„¢ canal tips which are constructed from memory foam and expand to create a comfortable seal within the ear. The tips are three times softer than skin and offer unprecedented levels of noise reduction and comfort
Complyâ„¢ screw locking system ensures the tips are securely mounted to the earphones and cannot come off in the ear
Supplied with soft silicone earbuds in small, medium and large sizes for optimum fit
Ergonomically designed speaker housing with angled front ensures easy insertion of tip into the ear canal.
GX200 Earphones Specifications
Driver 9mm drive units with neodymium magnets and titanium film diaphragms
Frequency Response 20Hz - 20kHz
Impedance 16ohm Nominal
Max power input 5mW
Total Harmonic Distortion (THD) <0.3% (1mW @ 1kHz)
Sound Pressure Level (SPL) 95dB (1mW @ 1kHz)
Cable length (left earpiece to jack) 1m
Connection 3.5mm stereo jack
