Stereo_Electronics 0 Report post Posted July 30, 2007 Headline The Headline is an amplifier designed to offer optimum performance from a variety of high impedance headphones. Fitted with a captive lead, the Headline takes its signal from the tape socket of any of our pre-amplifiers. It has its own volume control and is designed to be very, very quiet. It has the ability to drive most headphones to an adequate level (loud!) with low distortion. Headphones tend to be rather revealing of both noise and distortion, so we have spent a great deal of effort getting these parameters to extremely low levels. The Headline needs to be used with an external power supply (sold seperately)- both the iSupply (H) and NAPSC are suitable. If using a Flat-Cap 2x, Hi-Cap or Super-Cap you will also need a special interconnect, type SLIC. Specifications Suitable for headphones : 8 Ohms to 2 KOhms Frequency response : -3dB @ 10Hz & 72kHz Power output (into 8 Ohms) : 560mW per channel Max output voltage : 3.7V rms into 2kOhms Voltage gain : +13.5dB Dimensions (H x W x D): 57 x 121 x 187mm Made in EnglandNaim Headline :$1040 Recommended power supplies (sold seperately) - i-Supply ($315) or NAPSC ($845)For more information on Naim products click here. Share this post Link to post Share on other sites
