Stereo_Electronics
iBasso D2 pre-order
The iBasso D2 is available for pre-order, first shipment (Available by early next week) have been fully booked and we are taking orders for the 2nd shipment.
All pre-orders have to be made thru our store.
D2 available for audition.
- DAC + AMP combo
- Wolfson WM8740 DAC Chip + TI PCM2706
- USB signal input, provides I2S interface for decoding
- Dedicated MCU (Micro Controller Unit) to manager functions and settings of the DAC chip, to make the system more reliable.
- Work as a DAC+AMP Combo or a standalone AMP
- Four Channel + Buffer architecture in the amp section
- 2-Setting Gain Switch for impedance matching
- DIP socket design for OPAMP rolling.
- Two rechargeable 470mAh Li-polymer batteries with built-in current and charge management chip, and integrated charging system.
- Measures 51*20*94mm, and weights only 114g
Comes with AC adaptor, USB Cable, leather pouch, and Owner’s manual
Stocks for iBasso P2 available! Stock are limited.
Main Features:
- 3-Setting Bass booster
- 3-Setting Gain Switch for impedance matching, headphone impedance handling from 8~300ohm
- Two 2700uf JVC big capacitances.
- Two rechargeable 470mAh Li- polymer battery with built-in current and charge management chip, and integrated charging system.
- Up to 15 hours of play time and only 4 hours to charge the completely drained batteries
- High quality aluminum case with thick front panel, countersinking, and laser printing
- Case dimension is 3.2L x 2.5W x 0.93H (inch) or 82L x 64W x 23.5H (mm)
- Weights only 5.9oz (165g)
Comes with AC adaptor, connection Cable, leather case, and Owner’s manual
Edited by Stereo_Electronics
