Stereo_Electronics 0 Report post Posted May 22, 2008 iBasso has launched a new model - D2 Boa. It is shorter than the D2 viper by about 1cm and allows charging via USB. It will be available in two colours, dark green and silver. Main Features: - Wolfson WM8740 DAC Chip + TI PCM2706 - USB signal input, provides I2S interface for decoding - Work as a DAC+AMP Combo or a standalone AMP - 2-Setting Gain Switch for impedance matching - 470mAh rechargeable Li-polymer battery with integrated charging system - Measures 51*21*82mm, and weights only 108g - Battery life is 38hours - leather pouch, AC adapter, USB cable, warranty card, and owner's manual ---------------------------------------------------------------------------------------------------------- I-Qube is out of stock again and we are taking pre-order since there is limited stocks in this coming shipment. The following items will come free with the I-Qube, - Sanyo Eneloop AAA batteries - Multi-voltage charger - USB charging wire - I-Qube rubber band Share this post Link to post Share on other sites
