kookie 0 Report post Posted August 5, 2008 the stock cable is too stiff for my liking...anyone can recommend an alternative and where can i get it? and price also? Share this post Link to post Share on other sites
Guest dragonboy Report post Posted August 6, 2008 stereo sure have or u can also try jaben. Share this post Link to post Share on other sites
kookie 0 Report post Posted August 6, 2008 stereo sure have or u can also try jaben. er.. any idea wats the name of the replacement cable? xD.. can pm me how much they costs? and would the replacement cable sound as good as the stock cables? Share this post Link to post Share on other sites
Dictatormax 0 Report post Posted August 6, 2008 just take note that there may be warranty issue. clear this up before advancing will be best. [ clear up at Jaben or SE salesperson] Share this post Link to post Share on other sites
kookie 0 Report post Posted August 6, 2008 just take note that there may be warranty issue. clear this up before advancing will be best. [ clear up at Jaben or SE salesperson] er..?? triple fi 10 pro cables are detachbles and so are its replacement cables??...can u explain what you mean by warranty issue? Share this post Link to post Share on other sites
ralfale 0 Report post Posted August 6, 2008 Most like he is referring to the Westone ES2 cable. That will have slightly larger pin which might damage the original pin hole in the TF10. Share this post Link to post Share on other sites
Dictatormax 0 Report post Posted August 6, 2008 yes. since you are asking for alternative... that is the popular alternative currently available. though there should be other cable makers out there as well. Share this post Link to post Share on other sites
kookie 0 Report post Posted August 7, 2008 (edited) yes. since you are asking for alternative... that is the popular alternative currently available. though there should be other cable makers out there as well. ok thank you for your tips and warning any idea how that ES2 cable costs? Edited August 7, 2008 by kookie Share this post Link to post Share on other sites
Dictatormax 0 Report post Posted August 7, 2008 idk the price. mind someone help this friend out? Share this post Link to post Share on other sites
Stereo_Electronics 0 Report post Posted August 8, 2008 (edited) ES2 wire about $50+ Edited August 8, 2008 by Stereo_Electronics Share this post Link to post Share on other sites
kookie 0 Report post Posted August 8, 2008 ES2 wire about $50+ thanks, sounds reasonable but are the ES2 cable jack a little larger and would fitting it into the driver case somewhat cumbersome?? O.o Share this post Link to post Share on other sites
Dictatormax 0 Report post Posted August 8, 2008 (edited) required filing. larger in diameter[if i am not wrong] and definitely longer. in referring to the pins that is. Edited August 8, 2008 by Dictatormax Share this post Link to post Share on other sites
