Zane 0 Report post Posted March 24, 2010 Hello. I just finished soldering all the points but now i am currently stuck. I have no idea which is ground, left , right for the 10k pot and the 3.5mm stereo jacks. Anyone know how to identify them? Share this post Link to post Share on other sites
mouz 0 Report post Posted March 24, 2010 It's all in here bro. http://tangentsoft.net/audio/cmoy-tutorial...layout-0150.pdf Share this post Link to post Share on other sites
jtjy 0 Report post Posted March 24, 2010 (edited) BTTT Edited March 25, 2010 by jtjy Share this post Link to post Share on other sites
blippster 0 Report post Posted March 25, 2010 Hello. I just finished soldering all the points but now i am currently stuck. I have no idea which is ground, left , right for the 10k pot and the 3.5mm stereo jacks. Anyone know how to identify them? For the pot shaft facing you, 1 2 3 4 5 6 1/4 - ground 2/5 - out 3/6 - in Use your meter to check the jacks. Share this post Link to post Share on other sites
Zane 0 Report post Posted March 25, 2010 For the pot shaft facing you, 1 2 3 4 5 6 1/4 - ground 2/5 - out 3/6 - in Use your meter to check the jacks. Thanks Share this post Link to post Share on other sites
Zane 0 Report post Posted March 26, 2010 Okay, so just built finished my CMoy but the LED isnt turned on when i flip the switch. that means something is wrong right? What do you think it could be. Share this post Link to post Share on other sites
heady 0 Report post Posted March 27, 2010 hmm... is there sound from the amp? Share this post Link to post Share on other sites
dashbad 0 Report post Posted March 29, 2010 If you're getting sound and its just the LED that isn't working then you probably soldered it the wrong way round. If you're not getting sound either then check everything. Starting with all the connections off the board. Share this post Link to post Share on other sites
