kukubird 0 Report post Posted January 2, 2004 my first CMOY!!! with the HELP tropicalrips!!!!!!!!!!!!!!!!!!!! U ARE THE BEST use the same candy-tin.. hehehe going to make more!! haha.. want to try changing the CAPs, resistor and try to learn more!! anybody got any website on making a CMOY? want to know how to make one with extra op-amp/s instead of 1 and why need it and how it works!! hehe.. !! saw those made by tropicalrips, my hand very itch.... i want!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
kukubird 0 Report post Posted January 2, 2004 (edited) closed the workmanship very BAD... wahaha i got no technical background Edited January 2, 2004 by kukubird Share this post Link to post Share on other sites
kukubird 0 Report post Posted January 2, 2004 i didnt show the other side because.. when i drill the hole for the switch and light.. i push too hard and it drilled 2 small hole... (can see a small dot in the first PICT ?) wahahaha Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 2, 2004 nice, i got these green tins too, will be using it for my Monster A47 variant the led is very bright, will it drain the batt? the op-amp is a NJM4556? Share this post Link to post Share on other sites
N@Z 0 Report post Posted January 2, 2004 closed the workmanship very BAD... wahaha i got no technical background At least you built one that works! Well done! Share this post Link to post Share on other sites
kukubird 0 Report post Posted January 2, 2004 (edited) dont know leh... i use SUPER BRIGHT led... need to put a 330 resistor... wat is a MONSTER A47 !!!! sound very COOL!! i want to MAKE too!!!!!!!!!!! the OP-AMP u intro me one lor.. 4556AD wahaha if i use OPA2132PA and 2134P or 2134PA any diff? which one will let me heard the DIFFerences between 4556AD Edited January 2, 2004 by kukubird Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 2, 2004 (edited) i use 15k for led, its just to let know if the amp is on or off so its very dim and doesn't drain my batt my monster is using 2 op-amps, following the A47 design its a Cmoy with a buffer stage Monster A47 variant tread Edited January 2, 2004 by tropicalrips Share this post Link to post Share on other sites
kukubird 0 Report post Posted January 2, 2004 oh man..... i'm confused... wat is A47 design!?!? how u come out with this?!?!?!?! soooo strange... i want to learn!!!!!!!!!! Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 2, 2004 the A47 is the buffered Cmoy the OPA2134 will sound better on the Cmoy , more kick then the NJM4556 below is the drawing for the A47 design Share this post Link to post Share on other sites
kukubird 0 Report post Posted January 2, 2004 wow!!! thank u!! going to print it out and study it.. wahahaha man!! i LOVE U!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
augustineRS 0 Report post Posted January 2, 2004 Thats a big LED. At least u got it working. Mine had voltage drifting and i gave up on it. Need to work on a new board. My main concern now is actually how to make the casing since i do not have drills but i do have the altoids Share this post Link to post Share on other sites
ahgoh7 0 Report post Posted January 2, 2004 hi! wat's the cost of making something like that?? using a SR60.....does it improve the sound?? noob here.... Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted January 2, 2004 hi! wat's the cost of making something like that?? using a SR60.....does it improve the sound?? noob here.... total cost should be about $30 maybe less , depending on the quality of components u get. it should sound fine on a SR60, but the A47 is suppose to sound better, its design for the Grados Share this post Link to post Share on other sites
Tenson 0 Report post Posted January 2, 2004 (edited) It seems you have your own following now tropicalrips!! Nice looking amp kukubird! The electronics workmanship looks just fine though! Edited January 2, 2004 by Tenson Share this post Link to post Share on other sites
Musica 0 Report post Posted January 2, 2004 pardon my ignorance but what does cmoy stand for? today's the first time i have heard of such a... audio booster? Share this post Link to post Share on other sites
