dreamie
Advice on CMOY amp!
haha.. gain problems i guess...
don`t dunk the PIOs... they are good caps...
It sounds like a MALFUNCTIONING RADIO WITH EXTREMELY BAD RECEPTION!!! Lots of static like sound...
More like a wrong connection (or lack of) or solder bridge somewhere.
Checked my connections and they are fine... unsure.gif Both channels have the same problem... and they are also wired the exact same way. (wired 1 channel at a time, not 1 component at a time) unsure.gif
hmm... could you take a photo of board and post a copy of the version of the schematics you followed..?
I followed the exact same schematic on Chu Moy's Portable Headphone Amplifier article posted on Headwize, only modification will be the absence of the switch (at the input) and changing the input cap value to 2*0.068uF.
Just read the article. (http://tangentsoft.net/audio/input-cap.html)
it seems to only talk about the use of the input cap. . It did mention about the corner freq. to be below 20Hz... I did a calculation...
1/(1*(pi)*(100000*(2*(6.8*10^-8))) = 23.40513869Hz
I guess I will scrap the PIO caps for other applications. (A NON-portable preamp perhaps)
nope... its got nothing to do with the caps...
23hz rolloff is a very resonable figure. and it certainly would not induce static like distortion...
Try cleaning the underpart of the amp. Get some alcohol and a toothbrush and clean the soldered part to remove debris or flux. Also, scratch in between the traces with a blade to make sure nothing is touching and shorting. This actually solved the problem on a recent amp, the sound was very staticky and fuzzy, but this cleared it right up.
-ivan
Hi guys!
Tried the above stated methods and the problem still persisted.
Have bypassed the capacitor and used a 0.1uF capacitor but this time it seems to only be worse. I hear a loud humming sound... there used to be music in the past. blink.gif
Have decided to scrap the whole thing and rebuild another one. Any recommendations on cheap capacitors? party.gifheadphone.gif Thanks in advance!
i got phillips MKP for sale if you want some. very raved over cap by the taiwanese...
BTW, just rebuilt my CMOY. It's working now, but the volume is extremely low... dry.gif
