LiquidFX 0 Report post Posted May 17, 2004 Hi, I know this question might have been asked to death here, but are there any local (i.e. available in sg) batteries that provide the same (or almost the same) type of voltage and steep voltage drop off as the Plainviews? Getting plainviews from the States and importing them into Singapore is very expensive, so I am looking if there are any local variants that provide the same functionality. Thanks! Share this post Link to post Share on other sites
lekguan 0 Report post Posted May 17, 2004 (edited) Unfortunately, there is none as far as I know. However there is one that comes closer than normal 8.4V rechargables. http://www.mahaenergy.com/store/viewItem.asp?idProduct=273 This one doesnt really output so much voltage like plainviews but should be able to be still around 9V when dying out. I have previously checked with w3cube and they said they will bring in sometime in March. http://www.w3cube.com/ However I have not checked again, perhaps you might want to ask w3cube through email if they have really brought in such a battery. By the way, the plainviews can be had from www.headsave.com Edit: IIRC, the plainviews are 9.6V nominal whereas the maha is 9.6V peak. Do correct me if I'm wrong... Edited May 18, 2004 by lekguan Share this post Link to post Share on other sites
av98m 0 Report post Posted May 18, 2004 (edited) At 10usd a piece before shipping(which is quite affordable if you get a larger quantity of plainviews and spread out the shipping), they really are not much more expensive than the GPs you buy locally or other brands. There is a big difference performance-wise(measure them with a multimeter periodically and compare them to GPS, its a very obvious difference). The plainviews are also significantly heavier than GPs and Energizers etc because there are more cells packed inside, hence the higher voltage. If you want true 9 volts+ power from your rechargables,you'll have to cough up the extra $ (the GPs and Energizers give about 8 volts, my plainviews measure above 9 volts right up to the moment before they go flat). See this earlier thread for some info: http://www.sgheadphones.com/index.php?show...1&hl=plainviews Edited May 18, 2004 by av98m Share this post Link to post Share on other sites
Rameish 0 Report post Posted May 18, 2004 Varta (of Germany) makes a 9 volt that's quite good. You can pick up some at S$13.50 each at the battery shop in the basement of Sim Lim Tower. It's not a nominal 8.4 volt like the GP or the 7.2 volt nominal Eveready. Share this post Link to post Share on other sites
LiquidFX 0 Report post Posted May 19, 2004 Thanks for the information! Just FYI, I could find the mouse shaped charger that can charge dual plainviews together (as mentioned in http://www.sgheadphones.com/index.php?show...&hl=plainviews) at Suntec City Harvey Norman. Share this post Link to post Share on other sites
