tee 0 Report post Posted May 18, 2003 Rameish, Did you lose your favourite Grado Signature interconnect ? you didn't mention that when we met the other day. Maybe a friendly email to remind the borrower to return may help. Generally, similarities of designs and specs will indicate that one manufacturer is potentially outsourcing to the other as OEM. Of course, some cases are results of design copying. Denon designs and manufactures its own transport, as far as i know. Share this post Link to post Share on other sites
fishball79 0 Report post Posted May 19, 2003 Evil zen, I know the Denon DCD2880 (also known as 1650AR), one step below the S10 models, uses... *drum roll* SHARP! Replacement lens costed me $28. I dropped it in and it worked beautifully. Rameish, A crappy 2megapixel Fuji Finepix 2600. Has 3x optical zoom (totally 11x). It cant focus on anything within 1m of the lens so i can't take up close shots. Share this post Link to post Share on other sites
N@Z 0 Report post Posted May 19, 2003 If it has a macro setting try using that. Also for indoor shots if you have manual mode, change the white balance & iso settings. That should help alot. Another good tip is to use a tripod as sometimes bad shots are due to the tiny shake when you depress the shutter button. Share this post Link to post Share on other sites
fishball79 0 Report post Posted May 22, 2003 Thanks for the tips N@Z, Will open up cd player and try to take better pics... after climbing that mountain of study and assignments... sighs Share this post Link to post Share on other sites
N@Z 0 Report post Posted May 22, 2003 You're very welcome. Good luck! Share this post Link to post Share on other sites
