ginettaman 0 Report post Posted April 3, 2005 (edited) Hi, Didn't want to hijack huangyong's build post, but wanted show some pictures of my PPA build. Still not complete, but nearly there. have used Panasonic FC 470uf & 220uf capacitors, Koa Speer resistors, and have socketed the Gain resistors. I did get some ELNA Cerafine caps but have decided to keep them for a PPA2 or M3. As you see I have socketed the input, LED, power and switch for easy maintenance if needed. Still have to fit the Alps pot. Edited April 3, 2005 by ginettaman Share this post Link to post Share on other sites
digi01 0 Report post Posted April 4, 2005 (edited) have you cut the R channel's output pad?there are bug. P.S. good case,looks pleasure go ahead. BTW. I am going to make some solid buffer for roll ha3-5002. your friend,Z Edited April 4, 2005 by digi01 Share this post Link to post Share on other sites
heady 0 Report post Posted April 4, 2005 digi, I think ginettaman is using the original PPA v1.1 board. Share this post Link to post Share on other sites
digi01 0 Report post Posted April 4, 2005 the pad of poi of the original board is only for ALPS27. Share this post Link to post Share on other sites
ginettaman 0 Report post Posted April 4, 2005 Digi's right its the board from huangyong, but I hope he means cut the pad on the "Right Channel" The case is a Hammond Engineering, about the only descent case you can get in the UK, personally I prefer the aluminum heastsink cases Digi uses. Zang, when you say solid buffers, do you mean like the "Glassman" buffers, if so I would defiantly have a set of boards for them. Alan. Share this post Link to post Share on other sites
digi01 0 Report post Posted April 4, 2005 yes,Right Channel(RO) near the power input location.you should cut the top layer copper and bottom layer copper of "RO". my solid buffer is design for generic use.there are 2 design,SIP(system in package)01 & SIP02. SIP01 can roll OPA633 or HA3-5002,12 pcs HA3-5002 is too costly.I am glad to send 3 sets of these unit for your tryout. SIP02 can roll BUF634,pdip packaged.the buffer's bias is adjustable. Share this post Link to post Share on other sites
ginettaman 0 Report post Posted April 4, 2005 Zang, how many buffers does your sip01/02 use? Alan. Share this post Link to post Share on other sites
digi01 0 Report post Posted April 5, 2005 SIP01 is a single buffer,but very small,only 14x18mm.the project is still in progress.thanks. Z Share this post Link to post Share on other sites
huangyong 0 Report post Posted April 8, 2005 Wow, looks as cool as mine, i like that casing. wonder which model can fit the board? btw, what diode you use for power protection? Share this post Link to post Share on other sites
ginettaman 0 Report post Posted April 8, 2005 huangyong, Using a 50v 1.0A General Purpose Rectifier Diode, 1N4001 as Tangents part list. The case is a Hammond Engineering part no: 1455N1601 Have you got any further with yours, and do you know if anyone has completed from the boards you sold? Alan. Share this post Link to post Share on other sites
digi01 0 Report post Posted April 19, 2005 any update? P.S. the buffer is well done! url at: http://digi01.hk.st Share this post Link to post Share on other sites
huangyong 0 Report post Posted April 21, 2005 digi01, it looks cool, i need 3.. thanks. Share this post Link to post Share on other sites
huangyong 0 Report post Posted April 21, 2005 ginettaman, so far a few people from china had completed the amp with the same board, no serious problem occur. Share this post Link to post Share on other sites
huangyong 0 Report post Posted May 13, 2005 the hammond case cost 39!!! (farnell), but no choice... that's the best case.. btw, what kind of dc jack u use? Share this post Link to post Share on other sites
ginettaman 0 Report post Posted May 13, 2005 I'm using a plastic cased insulated DC jack. I haven’t finished my amp yet, but have had it bench tested just using opa134pa's The Hammond case is about the same price in the UK, I paid £10.95 for mine with the metal ends. Have you got yours up and running yet? Share this post Link to post Share on other sites
