Guest davidcsk2112 Report post Posted December 30, 2005 (edited) Hi, I'm intending to get the AKG K501s (which would suit my classical/choral/jazz music collection very well), but I noticed that they have a high impedance of 120 ohms. Does anyone have any cheap amps (around $150? the less the better, of course) to recommend that will be sufficient to drive these phones? Will consider second-hand ones. Edit: Will consider amps up to $250. Edited December 30, 2005 by davidcsk2112 Share this post Link to post Share on other sites
tbln 0 Report post Posted December 30, 2005 501s are a pain to drive and require a really muscular amp to make a difference. The cheapest amp that I have tried with these cans is the Original Master. At that price, I really have no cause for complaint. Without sufficient power, the bass never really shows itself thru the 501. Share this post Link to post Share on other sites
elmo 0 Report post Posted December 30, 2005 agreed with tbln! even with 120ohm,it should be easier to drive compared to my 250ohm beyer cans, instead it's the opposite.I have the opportunity to try on the pro-amp at AA for both K501 and other 250ohm beyer, the difference is obvious.Numbers are not everything. Share this post Link to post Share on other sites
lekguan 0 Report post Posted December 30, 2005 IMO its not a problem of "amp power". The signature of the cans are by nature, bass light. In other words, if you want more bass, u need something bass heavy. If bass is what you find is lacking, then probably the RA-1 would be a good try, and if it sounds like what you want, and you can find someone who can DIY a clone for you, then.... OTOH, I have a feeling that if bass is not of utmost importance to you, they might actually pair well with tube amps (Note here I'm making guesswork based on what I've remembered on the signature of K501, which is IMO lightweight, and having a upper mids suckout, hence only take it as a suggestion for you to try out, don't take it as it is). If that's the case you may want to try China tube amps (at this price range), probably the Little Dot II, though obtaining one might be a bit of a hassle. Seriously though at this price range, for real value for money, you don't have many choices. Share this post Link to post Share on other sites
Guest davidcsk2112 Report post Posted December 30, 2005 (edited) Having read the replies, I think I'd better audition them quite thoroughly before I buy to see if the bass is that lacking. Might fork out a bit more for a better amp if it's that bad. Does anyone know where I can get to test the K501s? ... I hear that Asia Sound at Adelphi (which sells the K501s) doesn't allow demos. Edited December 30, 2005 by davidcsk2112 Share this post Link to post Share on other sites
Mackie 0 Report post Posted December 30, 2005 (edited) I have the opportunity to try on the pro-amp at AA for both K501 and other 250ohm beyer, the difference is obvious. Does anyone know where I can get to test the K501s? ... I hear that Asia Sound at Adelphi (which sells the K501s) doesn't allow demos. AA denotes Anything Audio. It's located on 4th floor, Parklane Shopping Mall. Edited December 30, 2005 by Mackie Share this post Link to post Share on other sites
ckng 0 Report post Posted December 30, 2005 Having read the replies, I think I'd better audition them quite thoroughly before I buy to see if the bass is that lacking. Might fork out a bit more for a better amp if it's that bad. Does anyone know where I can get to test the K501s? ... I hear that Asia Sound at Adelphi (which sells the K501s) doesn't allow demos. Strange, they do allow auditions when I went there to buy my AKG271S 2 years back. Was looking for K501 but their particular unit sounded strange with their Cyrus amps thus settled for the 271 instead. I later bought the K501 used from this forum. One "problem" with the 501 is that it is inherently bass light. I am not much of a bass freak so I didn't mind much. So far I've tried it successfully with a DIY META42 headamp as well as a tubed XiangSheng 708B with good results. Regards CK Share this post Link to post Share on other sites
Charismatic 0 Report post Posted December 30, 2005 Hi David, Around $150 maybe you can get a used Creek? It used to be a good match with 501, you can check HeadFi. You would need to have good amp and source to pair with 501 or any high-end phone, lest you may end up thinking that the phone is not good. Maybe you would want to up your budget to get a better amp? I have hearnt the 501 with my diva amp during the SGhp meet at AA months back, although only for 5 mins, I was quite impressed. However, personally I'm looking forward to having a akg701. Share this post Link to post Share on other sites
Guest davidcsk2112 Report post Posted December 30, 2005 You would need to have good amp and source to pair with 501 or any high-end phone, lest you may end up thinking that the phone is not good. Maybe you would want to up your budget to get a better amp? I'm intending to use my iPod as a source, using 320kbps AACs. Will consider upping my budget to about $200 - $250 for a better amp. (There goes my upcoming music CDs splurge.) Is there any place that stocks a wide range of amps which I can audition? Share this post Link to post Share on other sites
evil-zen 0 Report post Posted December 30, 2005 Just to let you know that AKG 501 is a bass deficient headphones. No matter what you do, it will still be anemic compared to other cans. If you want bass to appear magically, it is not going to happen. Find a headphone that you like best tonally before getting an amp. If you really like the 501 and do not care too much about bass, then by all means get an amp based on the above recommendations. PS: I had a AKG 501 before. Share this post Link to post Share on other sites
ehlim 0 Report post Posted December 31, 2005 You can try AT-HA20 @Stereo Electronics. I bought mine few weeks ago and is happy using it with my HD-650. Comparing to PA2V2 which is my first entry amp, AT-HA20 is more powerful and better for HD-650. Regards Share this post Link to post Share on other sites
Charismatic 0 Report post Posted January 2, 2006 You would need to have good amp and source to pair with 501 or any high-end phone, lest you may end up thinking that the phone is not good. Maybe you would want to up your budget to get a better amp? I'm intending to use my iPod as a source, using 320kbps AACs. Will consider upping my budget to about $200 - $250 for a better amp. (There goes my upcoming music CDs splurge.) Is there any place that stocks a wide range of amps which I can audition? wide range...can try Adelphi. sugden headmaster and rkv at Electrades Graham Slee Solo at Soundscape Creek at Alpha audio Caiyin at Sound Precision but all out of your budget... Another way is to get some forumers to build one for you. Try the DIY forum here, they are all there. Share this post Link to post Share on other sites
Mackie 0 Report post Posted January 3, 2006 I reckon you had better audition the K501 before making a decision, lest you miss out on better options. I wouldn't even consider K501 to be suitable for Jazz.....maybe New Age, aside from its forte in Classical genre. Share this post Link to post Share on other sites
Guest davidcsk2112 Report post Posted January 3, 2006 I reckon you had better audition the K501 before making a decision, lest you miss out on better options. I wouldn't even consider K501 to be suitable for Jazz.....maybe New Age, aside from its forte in Classical genre. Yup, I'm planning to do that. Making a comparison between ATH-A900, DT880, and AKG K501... I'm still unable to make a decision because the shop I'm planning to audition them at is currently out of ATH-A900s. Share this post Link to post Share on other sites
