vii_haven
Earpeace Livewires
Uncle Wilson said to open and close my jaws a few times a while after the molding material was injected. Half-close, you could say.
Funny thing is, one side fits perfectly well, but I tend to lose the seal on the other side from time to time.
Here's just a simple review of the Livewires that I collected from Jaben last Friday. Thus far, it has gone through about 20 hours of music (recorded) and about 6 hours of stage monitoring use (live). Hope it helps some of you with your decision.
Just in case some of you are new here, this is a follow-up post to Mystery Sub $500 Custom Molded IEM at Jaben.
Premise
Some background here, I have listed below, the IEMS that I have owned and used the following both for personal audio listening and for stage monitoring for the past 5 years. I have also included brief thoughts about each, so as to facilitate the brief comparison later.
My music is played unamped, through an iPod 3G, a iPod Nano 1G, a iPod Shuffle 1G, and an iPod Shuffle 2G. Stage monitoring is through the Aviom and the Shure PSM700 personal monitoring system.
1. Shure E2 (Hated it.)
2. Shure E1 (Fabulous. My favorite single driver till the E4 came along.)
3. Shure E3 (Hated it.)
4. Shure E5 (Hated the cable, couldn't appreciate the sound)
5. Shure E4 (Fabulous. My favorite single driver. Period.)
6. Westone UM1 (Bang for the buck. Close to the E4 sound for less than half the price. Liked this too.)
7. Westone UM2 (Superb for relaxed listening. Extremely musical and engaging. Loved this while i had it, but missed the details i heard with the E1, E4 and UM1.)
8. Earpeace Livewires (My favourite so far.)
Build 4/5
Earpieces
IPB Image
IPB Image
I have seen (physically, not through reviews) and felt the Westone ES2, and the UE10Pro before. Both are similar to the Livewires as they are all made of acrylic. This is unlike the Sensaphonics 2X-S which is made of soft silicon. Having seen the two other IEMs made of acrylic, i would say that the build of the Livewires is quite comparable to them. The surface is smooth and there were no bumps or indents in the surface. Feels 'solid' in my hands, feels lighter than my UM2+Widex Custom molds.
They do have limited color choices, and the faceplate has to be either black or brown. And they don't do glitter in your earpieces. I originally wanted mine in either 1. Fully transparent red, 2. Fully transparent black with gold glitter OR 3. Fully transparent with silver glitter. But alas, i was give the order form with a measly few color options and no glitter. This might not be a problem to all, but the aesthetics do matter to me personally. Check out the Livewires website for the full color options if you're thinking of getting a set, or just email Uncle Wilson for an order form.
IPB Image
To differentiate the right earpiece from the left, there is a blue dot on the left earpiece to identify it, the other earpiece, will then obviously be the right one. The dot can be seen in the photo above.
Cable
The cable seems to be of high quality, looks extremely similar to the ones found on the Etymotic ER4 series and the Westone UM1 and UM2. Microphonics (when worn over the ear, that's the only way i use them) is virtually non-existant, comparable to the UM2 (which i used for the longest time before i went to the Livewires).
IPB Image
The 3.5mm audio jack, sadly, came in chrome rather than gold. The publicity photos and review photos i've seen and read about the Livewires show them in gold, so i was a little perturbed and disappointed when i saw that the sets that were sent to Jaben were in chrome. I would think a custom IEM aimed at performing musicians on stage would definitely have the jack in gold for durability purposes as the chrome jacks tend to oxidise and spoil much faster.
IPB Image
The cables are replaceable, just pop them out and put the new ones back in. To differentiate the cable for the right side and the left side (for those who are anal about the panning issues like me), the Livewire cable has a small red heatshrink (check out the photo above to see what i mean) on the cable that goes to the right earpiece.
IPB Image
IPB Image
The cable connector is unlike the standard 2-prong connector that can be found on Westone and UE IEMs. This one on the Livewires, according to the website, is a coaxial connector (think SCV cable point) that can rotate 360degrees instead of being in 1 fixed position. The Livewires website puts this as being an advantage for people who like to dangle their cable forward rather than hang it over their ears. I personally think the gold connector is a little huge and it is not very aesthetically pleasing. The photos above show the connector on the cable, and the connector on the earpiece.
IPB Image
The cables also come with a memory wire (seen in the photo above). This is short and works well, even with my Oakleys. This is completely unlike the one on the Shure E5 which is long and unwieldy. I like this feature a lot! Keeps the cables over my ears with them threatening to fall off.
Fit
I guess another major issue about custom IEMs is the fit. I had my impressions taken by Uncle Wilson from Jaben Networks. The Liveswires fit really well. The first time i inserted them i felt a little strange and sore. It was probably due to the fact that the Livewires was made of acrylic. After a day of using it, i must say that it no longer feels strange or sore. I guess it just takes a little getting used to. Its extremely comfortable, and the isolation is better than custom sleeves on your universal IEMs.
Sound
The sound from this is really good. The soundstage of the Livewires is much wider than the Westone UM2. Music sounds bigger and more enjoyable. There is more 'air' in the sound. The music is not as 'in-your-face' as the UM2, now, the music is as though the musicians took a couple of steps backwards, adding more space between you and them, and between themselves, thus details are more noticeable too.
The main difference between these and the UM2 is the details. The UM2 is an excellent IEM, enjoyable bass, and music just seems to melt into you when you listen, but as some has noticed, the details in the highs are missing from the UM2, but for me, that is exactly what contributes to the lush sound signature of the UM2. The Livewires, possess that detail in the high end. Now the acoustic guitars, acoustic piano and vocals suddenly have that sparkle again. And you can hear the 'air' when they resonate. The bass is deep, but controlled and not overpowering. The mids are present, but not as forward as the UM2.
I listen mainly to Rock, Jazz, Funk, Fusion, some Pop, acoustic music, and Indie. In my opinion, the Livewires is an all rounder, it has made my enjoy my varied choice of music so much more in the past few days, and it has also made my stage monitoring experience a whole lot more enjoyable due to the isolation and the wider soundstage.
Accessories 0/5
The Livewires came with ZERO accessories (discounting the ziplock bag and Uncle's namecard). This is the most disappointing part of the Livewires. For such a low price, I was not expecting much. But I thought the least the company could do, is to provide a decent hardcase to protect the Livewires and a 1/4 inch adaptor (for some monitoring systems). The Livewires, were afterall, designed for stage monitoring.
Also, I'm not too anal about this, but I was promised some Livewires souvenirs from the webmaster (apparently the co-founder of Livewires) when i had some email correspondance with them with regards to my order, but i never received them.
Turnover Time 2/5
I placed my order with Jaben on the 5th May. It arrived last Friday 22nd June. The Livewires website promises a 10day turnover time. Adding a week before and after for freight would add up to 24 days, and to give it some allowance, it would take a month (30days) for the Livewires to reach me. However, it took slightly over 1.5 months to reach me. There have been others who are complaining about the turnover time as well on Head-fi. But i think it'll get better once they start sorting out their process for mass production as it is a new company and i think they are swamped with orders for such a 'bang for the buck' product.
Verdict
I would say that at this price, for this sound quality and build, NOTHING COMES CLOSE to the Livewires. At this price, this product is EXCELLENT. In my opinion, it beats any universal single/dual/triple driver IEM hands down based on the fabulous sound and the fact that its a custom IEM, no universal can fit better and sound as good (even with custom sleeves).
I took an open mouth impression (mouth open throughout the entire process, had to try really hard to keep my saliva in..haha). The Livewires fit perfectly with no breakage in seal when i open my mouth wide.
Thanks for the excellent review xii haven (barring one or two typos, haha).
Looks like real bang for the buck stuff except for the small niggling little details like the chrome connector & total lack of accessories & limited color choices (I'm anal too, haha) but I guess that's how they can charge relatively less to than the others.
Thanks for the review :thumbup:
Very nice pictures you took, yummy stuff :DD
By the way, I thought monitoring systems used nickel for heavy-duty plugs?
Edited by radioactive28
That's what I thought too, the constant plugging and removing will wear out gold plating for pro equipment and will also remove the oxide layer from nickel plugs too.
BUT it was a terrific review otherwise. Good one. I am soooooo tempted. :drool:
--EDIT--
Just saw this review on CNet
http://crave.cnet.com/8301-1_105-9734014-1...l?tag=nefd.only
Edited by heady
Thank you for all your kind words.
Well, from my experience, the nickel plating tends to oxidise faster. Gold takes a much longer time to wear off.
Plus, i have never see professional In Ear Monitors with nickel plugs before. Only gold, no less.
Edited by vii_haven
