Northern Oak 0 Report post Posted May 20, 2008 Anyone has tried modifying the iBasso D2? Care to share what you have done? Share this post Link to post Share on other sites
Northern Oak 0 Report post Posted May 23, 2008 No one ..........???? Ok, I start the ball rolling then. Here's what I have done. Changed the silmic caps to Blackgates and Cerafine, I prefer the sound of Cerafine as it is brings in a sense of liveliness. Silmic to me has always been slightly warm sounding. Changed the .1uF decoupling cap across the supply pin to 1uF BG non-polar and MKP 1837 .1uF polypropylene cap. Found this to be the best compromise. Last but not least changing the default NE5532 (think this is used as buffer) to LM4562/LME49720. I had thought that the low output current for the LM4562/LME49720 might have some problems for me but it didn't, maybe becos I was using it to drive my UM2. One thing to note. With this configuration, I find that LM4562/LME49720 does not response well to .1uF decoupling cap across the supply pins. Sounded too aggressive. Please feel free to share your findings. Share this post Link to post Share on other sites
dle4e_2005 0 Report post Posted September 15, 2008 Have you tried the static mod? http://www.head-fi.org/forums/f5/ibasso-d2-static-mod-307333 And for list of recommended ompamp for Ibasso D2 viper you head to this thread here. http://www.head-fi.org/forums/f5/opamps-vi...23/index10.html I have only changed the opamp to LMH6622/THS4032. (Sound similar to iqube) Have not tried the predator alike opamp. (LTC6241HV/LMH6655) Share this post Link to post Share on other sites
evilmerlin 0 Report post Posted September 15, 2008 (edited) Does your Viper use the allen screws? I think the most I'll do is change opamps, changing caps is bit beyond me. Was informed that the Predator-like combo has got a short battery life, only 7hrs. Hows the iQube one? OT:Hmmmm...buy the Viper now...or wait for the Heron.... Edited September 15, 2008 by evilmerlin Share this post Link to post Share on other sites
dle4e_2005 0 Report post Posted September 15, 2008 Does your Viper use the allen screws? I think the most I'll do is change opamps, changing caps is bit beyond me. Was informed that the Predator-like combo has got a short battery life, only 7hrs. Hows the iQube one? OT:Hmmmm...buy the Viper now...or wait for the Heron.... Allen screw? I use the T6 screw to open up the housing. Correct only 7hours for the predator alike setup. For the iqube setup should be more than 12hours. ( I'm too scare to test out in case my battery run out while going back home.) You might want to try out both amp at Stereo but they only have stocked set of both. (Need to ask them if they allow opamp-rolling on their demo set) Share this post Link to post Share on other sites
evilmerlin 0 Report post Posted September 18, 2008 I did some quick calculations and figured that the twin batteries of the Viper actually provided more power than 6 AAA batteries so I picked up the Viper. Currently burning it in with ISL55002/THS4032. Share this post Link to post Share on other sites
Sean 0 Report post Posted September 19, 2008 I did some quick calculations and figured that the twin batteries of the Viper actually provided more power than 6 AAA batteries so I picked up the Viper. Currently burning it in with ISL55002/THS4032. You're here as well.. just saw you on ClubSnap haahaa Share this post Link to post Share on other sites
