Darkkopi 0 Report post Posted October 9, 2008 (edited) Mini USB digital in and 3.5mm analog in Automatic digital detection and input switching Several USB sample rates conversion Separate DAC chip(meaning we will not use the USB chip DAC but we will use a separate more high quality DAC chip) Tentlabs ultra low jitter special clock design. All clocks (including the Class D clock) will be synchronized for optimum sound performance Housing design and build will be comparable to version 1, just a little larger. L: 126mm, W: 70mm, H:23mm The battery cover will be deleted, only chargeable via mini USB cable (included) non user-replaceable AAA chargeable batteries used Volume knob indicator will be added. Further it will be the same electrical spec as the present iQube since they share the same class D amplifier stage. The sales price target is 499 euro inc VAT for the standard alu-black version. Introduction January/February 2009 time frame The white version volume knob came out looking blackish. This is due to the rendering and absolutely not the real case. The volume knob is the same alu as the casing. http://www.head-fi.org/forums/f75/new-iqub...-coming-370413/ Edited October 9, 2008 by Darkkopi Share this post Link to post Share on other sites
sghound 0 Report post Posted October 9, 2008 THE BE ALL & END ALL OF PORTABLE AMPS? Share this post Link to post Share on other sites
rko 0 Report post Posted October 10, 2008 THE BE ALL & END ALL OF PORTABLE AMPS? Maybe, untill the introduction of V3. Share this post Link to post Share on other sites
