Firefox 0 Report post Posted August 21, 2004 (edited) The force used to release the locking component of Neutrik Locking Jacks is somewhat excessive and may cause the chassis of the (pre)amp to bend. However, the jacks do look wickedly good! I've decided to come up with a simple and reversible solution to this problem. The problem lies with the spring used for the locking mechanism; It requires too much force to compress. There are 2 ways to deal with this. Namely, removing the locking mechanism OR replacing it with a spring with less tension. The latter requires additional money (and more importantly, time) to be spent (you'd typically need to buy a cheap ball-pen/ lighter to get the spring). This guide explains the former process. First, a look at the jack: and from the side we're interested in: We start by disassembling the jack. Begin by removing the screw at the side: The plastic assembly along with the contacts can then be seperated from the outer shell: The spring is right underneath the push-tab. Remove both from the plastic assembly: You can now see the locking-clip and the sponge/ foam like piece: Both need to be removed. Which leaves only the contacts with the plastic housing: Putting the jack back together is the direct opposite process except that we leave the sponge and locking-clip out. Replace the spring and push-tab into the plastic assembly. Replace the plastic assembly in the metal shell. Replace the screw (and the plastic washer!). Use the jack. =) Completed project: Edited October 11, 2004 by Firefox Share this post Link to post Share on other sites
heady 0 Report post Posted August 21, 2004 Excellent, firefox. thanks. Share this post Link to post Share on other sites
bpribadi 0 Report post Posted August 21, 2004 Yup ! That's exactly what I did On the last pic, you see the small plastic tab to lock the jack, I filed it a little bit, so unpluging the jack would be easier, but the locking function is still working. Share this post Link to post Share on other sites
Firefox 0 Report post Posted August 21, 2004 I personally felt that the locking function of the Neutrik Jack is not fool-proof. It's possible to yank the plug out with sufficient force. The clamping force of the contacts is such that it provides sufficient to prevent the plug from getting yanked out. Therefore, I decided to forgo the locking mechanism altogether. It's reversible and doesn't cost anything at all. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 22, 2004 Very helpful indeed! Share this post Link to post Share on other sites
