Necroist
Replacement Cables
Anyone knows where sells the cheapest replacement cables for the hd-497?
Hung Bros quoted me $40 which is too damn expensive.
Are there any cables that are meant for the hd-497 that can improve the sound quality? (like the clou red of the hd600)
Hmmm... if i can find the 2.5mm plugs someone here could make one for ya... but as firefox or ablaze (cant remember) mentioned, those plugs wont be as thin as the original hence it might need some filing, etc...
BTW, which cable model/length did they quote you?
How do you change the cable - simply pluck it off the L/R connections?
Deteoriation? Almost any quality <$5/m stock cable will sound more transparent, seemingly wider bandiwdth (more highs, bass).
where can i get this?
im also interested in getting replacement cables...not bcoz of improving the quality but my cable is spolit...R side cant hear....
if i buy the cable from LHS Electronics...do i need to do the filing and such...or juz buy and plug in???
Speak to Robert and he will advise U through the whole process. Please ask him to terminate the cables accordingly and bring your cans along.
If U have a contact problem, maybe the agent should take a look at it instead.
