kukubird
need a casing for my first CMOY!!! :) n alot MORE
yoz!!!
wahahaha
now i need a casing for it!!!!
all the shop at SLT sell black.. dull casing...
i'm looking for a see-through case.... ...translucence case..
1) anybody know where to get?
2a) i should get wat kind of drilling kit? (not those big big drill machine.. about the size of A4) ....
2b) if possible, i'm thinking of getting those KIT with alot of things inside <containing screwdriver, piler, all the drill and screw bits> which one should i get and where to get?? hopefully.. not those big big type.. b'cos i will be using for computer parts.
3) how do i secure the CMOY to the case? .. wahaha
4) if cannot get the transluence case.. maybe can get those tin-box? but where to get? now like all the shops sell paper packaging for sweets....
can try the Hudson mint tins like what i'm using
for drilling i use a Bosch cordless drill, need to look around in hardware shops
i usually use hot glue to secure my boards, but the board is so light, most of the time when the cables are in , the tension from the cables alone is enough to hold down the board smile.gif
CHEERS
the plastic Hammond case is also quite nice, i order them from Farnell, waiting for the one that will fit a 9v i think it may be able to fit 2 9v laying on its side
yoz!!!
wahahaha
2) Black & Decker RTX. It's B&D's answer to the dremel rotary tool. If you're into case-mods, you'd know that such a tool is extremely useful. Comes with the standard drill bits & cutting discs etc.
3) Depends. It can be hot-glue, blu-tack, tape, screws or stand-offs. Friction too!
4) Altoids sold at Guardian Pharmacies and 7-11.
Edited by Firefox
bought Hudson's instead laugh.gif this time its a green "herbal" mint
Edited by tropicalrips
