lengcm 0 Report post Posted January 25, 2004 (edited) The specs are as follows: Using Crystal CS4396 DAC resolution 24bit 192KHz multilevel sigma-delta with synchronous upsampling Clock Jitter Less than 14ps directly distributed to DAC 0dBFS signal output 2.3V RMS Output Terminals Gold plated RCA unbalanced and gold plated XLR balanced Frequency response Less than +/- 0.1 dB deviation 20Hz-20kHz Phase response Less than 2 degrees deviation 20Hz-20kHz Signal-to-noise ratio More than 105dB (XLR output) Crosstalk Less than -100dB Distortion (XLR) Less than 0.002% Distortion (RCA)Less than 0.003% Intermodulation Less than 0.002% (19kHz + 20kHz) Remote Control Philips RC-5 compatible IR system 36kHz modulation frequency Dimensions / Weight 8cm x 43cm x 29cm (HxWxD) / 13kg PM me for more information Edited January 26, 2004 by N@Z Share this post Link to post Share on other sites
dbreakup 0 Report post Posted January 26, 2004 How much? Share this post Link to post Share on other sites
lengcm 0 Report post Posted January 27, 2004 How much? PM me if you are really interested. Share this post Link to post Share on other sites
