bzy83 0 Report post Posted September 7, 2004 my new sound si coming soon, and i need cable to connect it with my AMP. where can i find affordable good quality cables? my budget is below S$50 Share this post Link to post Share on other sites
bzy83 0 Report post Posted September 7, 2004 actually i need such a pair of cables that one end is mono 1/4" connector the other end is normal RCA connector Share this post Link to post Share on other sites
bzy83 0 Report post Posted September 7, 2004 recommand me some shops that can find or can make such cable for me Share this post Link to post Share on other sites
huangyong 0 Report post Posted September 8, 2004 I can make for you. Share this post Link to post Share on other sites
bpribadi 0 Report post Posted September 8, 2004 DIY, or LHS @ SLT 2nd floor. Share this post Link to post Share on other sites
heady 0 Report post Posted September 8, 2004 Sorry, blur, don't know what is LHS? Thanks. Share this post Link to post Share on other sites
bpribadi 0 Report post Posted September 8, 2004 Shop name in SLT 2nd floor that sell cables and connectors (including the Neutrik connectors). I heard they can DIY cable for you as well. Share this post Link to post Share on other sites
bzy83 0 Report post Posted September 8, 2004 thank you for sharing information~ Share this post Link to post Share on other sites
heady 0 Report post Posted September 8, 2004 Hi Bram, thanks for the favour. What cable would you recommend for headphone extension? The S-VHS wire you mention has only two conductors right so must use the shield for the ground? I am also looking for a cable to replace my broken old headphone cable, so have to split into two separate 2 conductors, left and right. I don't think Cat-5 wire will be good, it is solid core and quite stiff and easy to break with bending. What do you think? Share this post Link to post Share on other sites
bpribadi 0 Report post Posted September 8, 2004 (edited) Here is the S-VHS cable I mentioned: I like to use is for: > Internal interconnect in the DIY amplifier > Interconnect between PCDP and Headphone Amplifier (1/8" jack and socket) This cable solved my hum problem previously I had with my CMoy. So it is proven effectively suppress hum Inside the cable are 2 coaxials, red and white, so the core is fully shielded. The hum rejection of this cable should be good, since this cable is designed for high frequency S-VHS signal. The size is just nice, fit tightly (sometime I need lubricant like WD40 to slot in the back spring > see foto) with the common 1/8" jacks and sockets You can buy it from the shop beside Kaichin (SLT 3rd floor), right side, for S$ 2.5 per meter. But for headphone cable, I think it is not Flexible enough. For cheap solution, you can get Daiyo cable, which is widely available at SLS (3rd floor) or Best Denki. It is flexible, and already come as a pair of coaxial, so it is easy for you to split it, cut the other ends to be connected to your headphone. It's cheap, around S$ 12.-. For expensive solution, you can browse this forum (Zu Mobius, etc.) Edited September 9, 2004 by bpribadi Share this post Link to post Share on other sites
lekguan 0 Report post Posted September 8, 2004 (edited) heady: I guess a relatively good one would be to get the Mogami starquad mic cable 2534 (www.team108.com). This is a 4-core one but if you were to make into a headphones extension you would use 1 conductor from each twisted pair for 1 signal (hence the starquad). That would still leave you with using the shield as the ground (except this one isn't tinned copper shield and its not braided like in most Beldens. I haven't personally tried it but IIRC the DT880s of av98m was moded with this mic cable. Perhaps he can tell more... Burp... Sorry we are OT. Edited September 8, 2004 by lekguan Share this post Link to post Share on other sites
bpribadi 0 Report post Posted September 9, 2004 (edited) You guys might want to check an interseting discussion here: http://www.sgheadphones.net/index.php?act=...t=15#entry43552 Bram Edited September 9, 2004 by bpribadi Share this post Link to post Share on other sites
Mackie 0 Report post Posted September 10, 2004 Hi Bram, thanks for the favour. What cable would you recommend for headphone extension? The S-VHS wire you mention has only two conductors right so must use the shield for the ground? I am also looking for a cable to replace my broken old headphone cable, so have to split into two separate 2 conductors, left and right. I don't think Cat-5 wire will be good, it is solid core and quite stiff and easy to break with bending. What do you think? U can't go wrong with Canare, Klotz, Belden and Mogami star-quad cables for your cans. Afterall, these are widely used in the pro audio industry and should beat any cheap consumer alternatives in terms of price and quality. My order of preference will be Mogami, Canare, Belden and Klotz. Share this post Link to post Share on other sites
heady 0 Report post Posted September 10, 2004 Mackie, thanks for the advice. Question is where do one get these cables and how much will expect to pay for them. It is quite intimidating to see the rolls and rolls of wires and not knowing the difference in them. Thanks again. Share this post Link to post Share on other sites
Mackie 0 Report post Posted September 11, 2004 (edited) As someone has mentioned above, start with LHS, 2nd floor SLT. All who are into DIY cables would and will continue to patronise this shop. Tell Robert (the boss) of your needs and he would make the necessary recommendation. I perceive the aforementioned cables should cost less than $10/m; a very safe and sure assumption on my part. He also sells all kinds of connectors and at reasonable price too. This is one place where I'm assured I won't be fleeced. U should consider my power buy thread on classified section regarding extension cable but U should proceed with repairs of your broken headphone cable first. Bring along your cans to LHS and seek Robert's advice. If he's confident enough to undertake the repairs, oblige if U wish albeit he charges a fee of $10. Edited September 11, 2004 by Mackie Share this post Link to post Share on other sites
