Kippei
Pending MO for Millet Hydrid boards
look here for my posts: http://headwize.com/ubb/showpost.php?fnum=...=47187&fpage=20
and this: http://headwize.com/ubb/showpost.php?fnum=...=47193&fpage=20
I've recorded down the hum, and analyzed the spectrum. turns out to be 50Hz, which means from the mains, am I correct to say so?
grounding, I use the big copper line at the bottom
wat do you guys reckon causing the hum?I've tried to shield away the signal lines as you've seen with all those small wires twisted around the signal wires then ground one side of it.
only the lead wires to the tube that is not shielded
i had an old japanese airtight tube amp, transformer faulty after a few years, similar 50hz hum.. ppth.gif
trafo's fault?
but I've tried grounding the input to the op-amp (L channel only). then turn it on.
no hum on L channel, R channel has the hum. so I dont think it's trafo's problem. if it is, it should be there no matter wat, am I right?
Okay back really less den $100...
Couldnt find the 15 -15v transformer... minus the jacks
Total parts damage from Koba is $52 after some heavy discount. Might be less if not for the fake alps. $15
haha
those 2 extra heatsinks are not really req, but being kiasi, so just put there
but I think can do without. totally no heat out of it
but the heater sink is a MUST
I found out the stupid hum just due to the damn contact of the screw on connector
sheesh
I accidentally pulled the cables from trafo and the board
then hum went away
hahahaha
so silly
after numerous amount of hours spent staring at this damn thing
The tube socket... I realise i got the 7 pin one which type of stripboard u using also
Edited by Kippei
Hmmm I think i halt the building, until I have done the nesscessary preparation... I was thinking of casing it in a acrylic casing
