evil-zen 0 Report post Posted August 14, 2006 My Gilmore headamp has a preamp output but my soundcard doesn't have a mike preamp. I was wondering if i managed to connect a mike via mini to female mini cable to male rca into rca inputs, could the preamp essentially function as a mike preamp? Is the signal strong or clean enough? What is so special about mike preamp over the conventional 'hifi' preamps? I asked so that I wouldn't waste money making cables that didn't work. Thanks in advance. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 15, 2006 In a nutshell, gain consideration. LINE level (audio) sources are much-amplified signals over MIC (microphone) level signals. Line level is usually between -10 to +4 dBm in strength while MIC levels are normally -60 dBm. Share this post Link to post Share on other sites
heady 0 Report post Posted August 15, 2006 In a nutshell, gain consideration. LINE level (audio) sources are much-amplified signals over MIC (microphone) level signals. Line level is usually between -10 to +4 dBm in strength while MIC levels are normally -60 dBm. I am no expert like Mackie but in the last few months, I have been trying to get a mic input into a MP3 line in and have had no success despite spending money on line impedence transformer, plus all sorts of advice. Not easy thing to do. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 15, 2006 wanna diy? http://www.ee.washington.edu/circuit_archi...its/micamp.html Share this post Link to post Share on other sites
evil-zen 0 Report post Posted August 15, 2006 Thanks Mackie. But what if I don't turn up the volume as much? Won't it be lesser gain then? Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 16, 2006 (edited) Thanks Mackie. But what if I don't turn up the volume as much? Won't it be lesser gain then? It's the inherent maximum gain (ratio of output signal/input signal) of the pre-amp design. U need a pre-amp with much higher gain to amplify the comparatively weak input signal from a mic as mentioned in my earlier post. An audio pre-amp will have lower gain than a mic pre-amp as line level input signal is stronger. Edited August 16, 2006 by Mackie Share this post Link to post Share on other sites
evil-zen 0 Report post Posted August 17, 2006 ahh thanks Mackie. Looks like it won't be successful. I'll depend on my MD player then. Share this post Link to post Share on other sites
