heady 0 Report post Posted September 18, 2006 I am looking for suitable lapel mics for recording on a M-Audio MicroTrack device. I have tried a omni Beyer, which has too high an output. I have tried a cardoid AudioTechnica which output is too low and is also cumbersome because of the extra battery pack. Any suggestions? Or can I use a resistor to lower the output from the Beyer mic? From hot to cold? Thanks guys and gals (must be fair). Share this post Link to post Share on other sites
Mackie 0 Report post Posted September 18, 2006 (edited) I wonder if this will work for you. Read "Modification ideas" in the following link: http://66.102.7.104/search?q=cache:FV4-70G...us&ct=clnk&cd=2 I prefer a variable approach as too low an output from the mic will require higher gain of mic amp to drive it to a certain spl, which in turn, results in greater hiss. Edited September 18, 2006 by Mackie Share this post Link to post Share on other sites
