kimi 0 Report post Posted September 30, 2006 Dear All, may I know what is the best software version for the i-RiverH340 and also should I Rockbox it? Share this post Link to post Share on other sites
theory_87 0 Report post Posted September 30, 2006 go rockbox. the FLAC, gapless, excellent EQ is the one to die for... Share this post Link to post Share on other sites
kimi 0 Report post Posted October 3, 2006 Thank you for your replies.Will upgreat the firmware first and later to Rockbox.Cheers. Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 3, 2006 Thank you for your replies.Will upgreat the firmware first and later to Rockbox.Cheers. Just be careful. That time I rockbox my H340 & the player hang after accidentally pressing something. Not even able to off the power. Luckily, its power off till battery was drained off. Check the player & found that its still ok after fully charged again. Note that warranty is not cover if something happened to your DAP after using rockbox. Share this post Link to post Share on other sites
replay 0 Report post Posted October 3, 2006 Just be careful. That time I rockbox my H340 & the player hang after accidentally pressing something. Not even able to off the power. Luckily, its power off till battery was drained off. Check the player & found that its still ok after fully charged again. Note that warranty is not cover if something happened to your DAP after using rockbox. In fact I experienced hanging quite a few times with rockbox already. When that happens I'll push the reset button and everything is fine again. Can't be helped since the rockbox firmware is not complete yet. Even so it still offers much more functions than the original firmware. Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 3, 2006 In fact I experienced hanging quite a few times with rockbox already. When that happens I'll push the reset button and everything is fine again. Can't be helped since the rockbox firmware is not complete yet. Even so it still offers much more functions than the original firmware. Oh, really forget about the reset button. But find that the rockbox display really suck so I changed back to the Iriver Firmware. Another thing is the rockbox software is not user friendly no doubt that its operate faster than the Iriver firmware. Talking about H340, do you use the external battery pack ? Using my H340 for 1.5 years but really don't know what is really the purpose of this external battery pack. I did try to use it but u need to disconnect the battery pack if not using the DAP or else its will drain off your H340 battery. Really find it very troublesome. erm...is it really neccessary to upgrade the iRiver firmware first before installing RB since RB would override the iRiver anyways... Please read below for Iriver H340 rockbox software installation instruction : http://www.rockbox.org/twiki/bin/view/Main...river_jukeboxes Just follow & you can't really go wrong........ Share this post Link to post Share on other sites
radioactive28 0 Report post Posted October 3, 2006 Are you using the iPod batt for your replacement? Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 3, 2006 I cannot stress how much I recommend h1xx/h3xx users to upgrade to the 2200mah battery...swapped mine sometime ago and it now still plays 20+ hours of .flacs... Wow 20 hr ? Mine only last for the most 6 hours with volume set at 23 as I am using a headphone. Where did u upgrade your battery ? U mean that the stock battery of the H340 is not 2200mah ? Share this post Link to post Share on other sites
replay 0 Report post Posted October 3, 2006 Wow 20 hr ? Mine only last for the most 6 hours with volume set at 23 as I am using a headphone. Where did u upgrade your battery ? U mean that the stock battery of the H340 is not 2200mah ? You can find the batt at worcell. Comes with instructions on how to replace it. Mine also lasts at most 6 hrs.. cos I'm using it at max volume. I think it'll last only 4 hrs + if I play only wavpack files.. Share this post Link to post Share on other sites
radioactive28 0 Report post Posted October 3, 2006 The default batt is only 1300mAh... Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 3, 2006 You can find the batt at worcell. Comes with instructions on how to replace it. Mine also lasts at most 6 hrs.. cos I'm using it at max volume. I think it'll last only 4 hrs + if I play only wavpack files.. Sorry, I don't quite understand why your one only last 4 hour. As wat I see, u are using a portable amp. Your source volume only need to set to 15 ( using Iriver Firmware ). Your portable amp volume should be able to blast your earphone. Am I right ? Share this post Link to post Share on other sites
genocide 0 Report post Posted October 4, 2006 wh spoilt??thtaas fast ^^; maybe played too much game at it eh Share this post Link to post Share on other sites
genocide 0 Report post Posted October 4, 2006 hahaha tats explain y u using ur discman the other day ^^; anyway h340 it is a great device if ur not considering size Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 5, 2006 Which player would u all choose to upgrade from the H340 for better SQ ? Look like not much choices at all. Share this post Link to post Share on other sites
Jeremy 0 Report post Posted October 5, 2006 ' date='5 Oct 2006, 06:24 PM' post='82229'] For me, maybe the Teclast DAP? (just for trying though) Or the iPod ultimately for me if I have no other choice. But will only go for the 60G iPod 4th Gen as it supposedly uses a better DAC and it's the only DAP that I've tried that produced virtually no hiss with the ER4Ps. Sigh.. iAudio ain't pimping me for now. Although it sounds good. If possible I would like another H340 with a true line out. Fat hope, I guess Teclast DAP - Does it have high storage model ? I can't find 20G & above from their site. How is iAudio sound as compare to Iriver ? Are they using the same DA processor ? Haven't really heard before. Thanks. Share this post Link to post Share on other sites
