ezzo 0 Report post Posted November 21, 2007 (edited) Hi, I am in the process of building a CK2III amp and like many other DIY amps, they only accept a single input. However, I have 2 sources but no switch box. Is it advisable to install 2 sets of RCA then connect them together then to the single input on the PCB? Will there be any degradation of SQ and any other issues that might result from it? I will be installing a ground loop breaker between the amp and the power ground anyway. Thanks! Edited November 21, 2007 by ezzo Share this post Link to post Share on other sites
zer061zer0 0 Report post Posted November 21, 2007 why not add a switch inbetween the 2 inputs, i did that for my xiangsheng when i recase it. Share this post Link to post Share on other sites
ezzo 0 Report post Posted November 23, 2007 Hmmm, thats a good idea. So I reckon there will not be any degradation of SQ?? Share this post Link to post Share on other sites
zer061zer0 0 Report post Posted November 24, 2007 disintegration well possibly, but then again how noticeable and whether if its more convenient for you to switch sources. Pros and cons, but i havent notice really prominant disintegration in SQ in my amps. Share this post Link to post Share on other sites
Fuzzy Fuzzbucket 0 Report post Posted November 24, 2007 well install a selector switch then. about SQ, if u worry alot, then, make sure the wires are as short as possible from the inputs to the selector switch.. Share this post Link to post Share on other sites
1bit 0 Report post Posted November 24, 2007 Well, if you can find a 4pdt with centre off switch that'll be better. Basically it has 12 pins, you wire the centre 4 pins to the amplifier R+, RG, L+, and LG. The side pins to the respective source. The centre off means that the switching will not be direct from source A to B but there's a middle position that's actually an off position, the amplifier will not be connected to any source. This will make hot switching safer. Share this post Link to post Share on other sites
ezzo 0 Report post Posted December 2, 2007 Thanks for the replies! I think I will just stick to no switches since I will not be powering up two sources at the same time. Plus I have gotten the Alps 50k pot, not cheap man Share this post Link to post Share on other sites
