williamneo 0 Report post Posted January 8, 2008 Good day everyone! My name is William, I understand that there is alot of people like me who isn't really good at electronic or had a hard time reading those schmatic diagram. So I have write up a blog on sharing how to build a cmoy amplifier by using picture of step by step tutorial. For those of you who interested please check my blog at http://www.williamneo.blogspot.com/. Hope this help! sincerely William Neo Share this post Link to post Share on other sites
Stereo_Electronics 0 Report post Posted January 8, 2008 Well done. Share this post Link to post Share on other sites
williamneo 0 Report post Posted January 8, 2008 Thank You! You have a shop in woodland haha, i stay woodland too! Share this post Link to post Share on other sites
JaiX 0 Report post Posted January 8, 2008 Nicely done indeed! One question though... What's the component part of the pot that you're using? Share this post Link to post Share on other sites
mouz 0 Report post Posted January 9, 2008 Nice Job, correct me if I'm wrong but isn't there suppose to be a 10 KΩ 1/4W resistor between the LED and the +ve at step 4? You might wanna add that in cos I read somewhere on tangentsoft the LED will burn up if it's missing. Share this post Link to post Share on other sites
1bit 0 Report post Posted January 9, 2008 (edited) yeah you really need the led resistor, if you don't put it in, the led will draw so much current that the battery won't last long. the resistor there will control the current. For 9v battery, the resistor's value can range from 560 to 10k ohm, depends on how bright you want the led to be. Try to use as high value as possible though. a little comment: you should probably add more detail on how to solder those jumper wires (the green links in your diagrams) i think beginners might get confused about this. Actual photos would be nice. another thing, metal film resistors (usually blue colored) would be more suitable for an amp. it's still quite cheap at 10 cents a piece iirc. i love the way you put pictures to describe the parts list. but looks like the actual audio jacks that you use is different from the picture. and the main point is that you give a nice layout that is easy to solder the jumper wires (no messy wire crossings) cool Edited January 9, 2008 by 1bit Share this post Link to post Share on other sites
mouz 0 Report post Posted January 9, 2008 sorry ar, OT a bit ask a suakoo qns, wats the diff between blue and beige resistors? to indicate 1/4w or 1/8w? Share this post Link to post Share on other sites
zhang_junyang 0 Report post Posted January 9, 2008 The common through hole resistors usually use blue colour to coat the 1% tolerance resistors and beige colour to coat the 5% tolerance resistors for the 0.25W resistors. Share this post Link to post Share on other sites
mouz 0 Report post Posted January 9, 2008 (edited) thanks! but is there anything to indicate 1/4w or 1/8w, etc? Edited January 9, 2008 by mouz Share this post Link to post Share on other sites
williamneo 0 Report post Posted January 9, 2008 Nice Job, correct me if I'm wrong but isn't there suppose to be a 10 KΩ 1/4W resistor between the LED and the +ve at step 4? You might wanna add that in cos I read somewhere on tangentsoft the LED will burn up if it's missing. Yup i didn't add the resistor there on my amp, i will update the page asap. In fact so far my led didn't burn up might be due to i am using 9v batt instead tangent is using 18v if i not wrong. yeah you really need the led resistor, if you don't put it in, the led will draw so much current that the battery won't last long. the resistor there will control the current. For 9v battery, the resistor's value can range from 560 to 10k ohm, depends on how bright you want the led to be. Try to use as high value as possible though. a little comment: you should probably add more detail on how to solder those jumper wires (the green links in your diagrams) i think beginners might get confused about this. Actual photos would be nice. another thing, metal film resistors (usually blue colored) would be more suitable for an amp. it's still quite cheap at 10 cents a piece iirc. i love the way you put pictures to describe the parts list. but looks like the actual audio jacks that you use is different from the picture. and the main point is that you give a nice layout that is easy to solder the jumper wires (no messy wire crossings) cool As for the led resistor i will update that on e blog. The comment regarding the jumper wires for real pic is abit hard for me my phone camera can't take very close shot it look blur, i will try to borrow a digit camera to actually take some real pic so that i can update it... thanks for e comment Nicely done indeed! One question though... What's the component part of the pot that you're using? Oh you mean the volume control pot i am using? For that i just buy those normal dual pot you can find at SLT. Share this post Link to post Share on other sites
JaiX 0 Report post Posted January 9, 2008 Yup i didn't add the resistor there on my amp, i will update the page asap. In fact so far my led didn't burn up might be due to i am using 9v batt instead tangent is using 18v if i not wrong. As for the led resistor i will update that on e blog. The comment regarding the jumper wires for real pic is abit hard for me my phone camera can't take very close shot it look blur, i will try to borrow a digit camera to actually take some real pic so that i can update it... thanks for e comment Oh you mean the volume control pot i am using? For that i just buy those normal dual pot you can find at SLT. Yup! The volume control pot... hmmm... is there a value for the pot, eg 10K, 100K etc? Also... what's dual pod? Can share how you drilled the holes for the tin? Thanks! Share this post Link to post Share on other sites
williamneo 0 Report post Posted January 9, 2008 (edited) Yup! The volume control pot... hmmm... is there a value for the pot, eg 10K, 100K etc? Also... what's dual pod? Can share how you drilled the holes for the tin? Thanks! I use a single hole puncher brought from bookstore. http://williamneo.blogspot.com inside got a the picture of it under tools. the value of the pot is 10k. Dual pot has 6 pin and single has 3 pin. dual pot for stereo L/R channel while single only has mono channel either L or R. Edited January 9, 2008 by williamneo Share this post Link to post Share on other sites
williamneo 0 Report post Posted January 9, 2008 ok i have updated the cmoy amplifier instruction: Added: 10k dual pot onto part list 2 added: R6 10k ohm 1/4W resistor onto part list 2 added: R6 Resistor for power led and save current flow One last stuff I gonna add in is a Picture instruction on how to solder the green line jumper as commented by 1bit. I am very appreciate all your comment and all the question so that I will be able to add in to the instruction blog in order for many more ppl to understand easily, once again thank you guyz. Share this post Link to post Share on other sites
JaiX 0 Report post Posted January 9, 2008 Thanks! Saw the tool... Now I'm thinking of doing up a cmoy... the instructions are very clear... thanks once again... Share this post Link to post Share on other sites
mouz 0 Report post Posted January 10, 2008 no worries man, we're all learning here, it's always good to share. Share this post Link to post Share on other sites
