heady 0 Report post Posted April 30, 2008 (edited) Here's pics of my Enhanced USB Monica. That's its official name, quite a mouthful. How's the sound? Very very good. I particularly enjoy it with my Pimeta and DT150 although the headphones has a faulty left driver which on some tracks drive me crazy. Now to deal with the DT150's problem, bought it second hand without testing. Had no pads so couldn't test until I got pads which was weeks later. Such foolishness, I amaze myself sometimes. Edited May 2, 2008 by heady Share this post Link to post Share on other sites
mouz 0 Report post Posted April 30, 2008 (edited) Nice work, any idea where i can get those casings? Edited April 30, 2008 by mouz Share this post Link to post Share on other sites
alvin1118 0 Report post Posted April 30, 2008 SLT sunlight(3rd floor) has the casing Share this post Link to post Share on other sites
heady 0 Report post Posted April 30, 2008 SLT sunlight(3rd floor) has the casing Yes. $5.90. Manufacturer is "Future Box", model is "FB No. 16". Share this post Link to post Share on other sites
mouz 0 Report post Posted May 1, 2008 (edited) Thanks Guys! Gives me an alternative to buying hammond casings BTW, is that interconnect made from cat5 network cable? Edited May 1, 2008 by mouz Share this post Link to post Share on other sites
heady 0 Report post Posted May 1, 2008 The interconnect is a Canare L-2B2AT cable with Neutrik 3.5mm stereo plug. DIY from parts from LHS. Share this post Link to post Share on other sites
mouz 0 Report post Posted May 2, 2008 Looks like a pretty good cable with foil shield to stop EMI, RFI. That's going on my list of DIY materials, thanks for sharing this Say, do you think lining aluminium foil (those found at the supermarket) inside the case will help shield out EMI RFI? Share this post Link to post Share on other sites
heady 0 Report post Posted May 2, 2008 Looks like a pretty good cable with foil shield to stop EMI, RFI. That's going on my list of DIY materials, thanks for sharing this Say, do you think lining aluminium foil (those found at the supermarket) inside the case will help shield out EMI RFI? Mouz, This is what I understand from reading. First the aluminium must be grounded (earth in mains?) Second, aluminium is only good for RFI. For EMI, the shield must be mu-metal, which means metal which are capable of being magnetised or attracted to magnets. HTH heady Share this post Link to post Share on other sites
mouz 0 Report post Posted May 2, 2008 So in the Canare cable I suppose it uses the foil for RFI. Wonder what it uses for EMI shielding, grounding the drain wire to signal ground? Share this post Link to post Share on other sites
heady 0 Report post Posted May 2, 2008 So in the Canare cable I suppose it uses the foil for RFI. Wonder what it uses for EMI shielding, grounding the drain wire to signal ground? The foil is wrapped and contacting the signal ground, so it is connected to the signal ground. I believe the foil will minimise RFI but I don't think it is very effective for EMI. For EMI, it is more effective to place the source of the EMI (usually transformer and AC) as far away as possible from signal cables or inside a Faraday cage. Share this post Link to post Share on other sites
mouz 0 Report post Posted May 2, 2008 Thanks for the tips heady, think this will come in pretty handy on builds that uses transformers in the future. Share this post Link to post Share on other sites
