ckng 0 Report post Posted August 11, 2003 Hi, Which shop sells the audio grade components for building stuff like amps, etc? The generic ones are easy enough. Or do everyone order online from the likes of RS Components (Singapore), Farnell, etc ? Thanks in advance. Regards CK Share this post Link to post Share on other sites
jarthel 0 Report post Posted August 11, 2003 I have an Australian version of RS's and Farnell's catalog. There are no "audio-grade" resistors or capacitors in there. no Cardas female RCA as well or any other so-called audio-grade components. But the parts are decent but not what you would call "audio-grade". If you want audiograde, try partsconnexion.com (Canada), percyaudio.com (USA) and hndme.com (USA). There are other places but those are the ones I have dealt with. Someone mentioned that there's a local Singapore shop that sells Riken (audio-grade) resistors. They might have other things like capacitors and etc. Share this post Link to post Share on other sites
jtfoo 0 Report post Posted August 11, 2003 In Singapore you can try the following places, Well Audio - Burlington Sq, Martin Electronic - Same place as above Larry - Basement of Peoples's Park Centre Koba - 3rd storey of PEoples Park. You gotta to know what you're looking for before hunting there. AHF Artaudio - http://www.ahfartaudio.com/ Zenn Audio - http://www.zenn.com.sg/ for DACT Attenuator. Shops in SLT, if you know what you're looking for. Share this post Link to post Share on other sites
ckng 0 Report post Posted August 12, 2003 Thanks jtfoo, I'll check them out. I have been out of DIY electronics for years since I left poly. The last I bought stuff from SLT, they are pretty generic. Regards CK Share this post Link to post Share on other sites
ckng 0 Report post Posted August 12, 2003 Hi, Are Elna Starget caps considered "Audio Grade"? They are listed as so in the RS catalog.... Regards CK Share this post Link to post Share on other sites
jtfoo 0 Report post Posted August 12, 2003 Hi, Are Elna Starget caps considered "Audio Grade"? They are listed as so in the RS catalog.... Regards CK Yes, they are. But they are not as popular as their brethren, like Cerafine and Silmic. Share this post Link to post Share on other sites
ckng 0 Report post Posted August 13, 2003 Hi, Are Elna Starget caps considered "Audio Grade"? They are listed as so in the RS catalog.... Regards CK Yes, they are. But they are not as popular as their brethren, like Cerafine and Silmic. I see. Thanks. Just got them from RS components. Will be using them for power supply of a META42, should be more than enough. By the way, any idea if there's a big difference between those audio-grade resistors like the Vishays vs "normal" 1% tolerance resistors? Is this difference audible? Regards CK Share this post Link to post Share on other sites
Guest Ruach Report post Posted August 13, 2003 CKNG, What values of Starget caps did you purchase? Stargets are normal audio grade caps. You should have tried Koba where you may find better grade caps at lower prices. I can recommend you some. Just tell me the values. Yes, there is some difference in the sound performance, the magnitude depending on whether you are using them in the signal path. Share this post Link to post Share on other sites
ckng 0 Report post Posted August 13, 2003 Thanks Rauch, the Stargets I got are 470uF 35V electrolytics. In the schematic, they are simply used as reservoirs and not in the signal path, shouldn't have a very large impact on sound right? The others I am looking for : 0.22uF 50V polypropylene x 2 6.8uF 50V WIMA MKS2 (or equivalent) x 2 Resistors if you can help me as well 1Kohm x 2 500Kohm x 2 470ohm x 2 4.7Kohm x 2 2.2Kohm x 2 220Kohm x 2 100ohm x 4 47ohm x 2 These appear in the signal path and feedback path. Wonder how much do I lose if I use regular 1% resistors. heh. Thanks again! Regards CK Share this post Link to post Share on other sites
Barradio 0 Report post Posted August 13, 2003 Ruach, what are the better audio caps at Koba? Can recommend some of it name. Cheers Share this post Link to post Share on other sites
Guest Ruach Report post Posted August 13, 2003 Nichicon KG Gold Tune (for larger values i.e. 10,000uF and above) Nichicon MUSE Elna Silmics Sanyo Oscons Panasonic FC BHC and many more. one need to know the good stuff when shopping at Koba Share this post Link to post Share on other sites
Guest Ruach Report post Posted August 13, 2003 For the 470uF 35V, try Elna Tonerex 2200uF 42V ($2.50) (these are great audiophile-quality caps for reserviors), the higher capacitance should not have any impact on the circuitry stability. As for the film caps, you should be able to source for them at Koba. As for the resistors, if you are not too fuzzy over the sound, they sound almost alike. My preference is for Riken resistors. Share this post Link to post Share on other sites
Barradio 0 Report post Posted August 13, 2003 Thanks Ruach will vist Koba. Share this post Link to post Share on other sites
ckng 0 Report post Posted August 13, 2003 For the 470uF 35V, try Elna Tonerex 2200uF 42V ($2.50) (these are great audiophile-quality caps for reserviors), the higher capacitance should not have any impact on the circuitry stability. As for the film caps, you should be able to source for them at Koba. As for the resistors, if you are not too fuzzy over the sound, they sound almost alike. My preference is for Riken resistors. Thanks Rauch, I'll check them out. Regards CK Share this post Link to post Share on other sites
jtfoo 0 Report post Posted August 13, 2003 The others I am looking for : 0.22uF 50V polypropylene x 2 6.8uF 50V WIMA MKS2 (or equivalent) x 2 The 6.8uF is kinda difficult to find in Singapore, esp if you want the WIMA MKS2 which has a small footprint. I suggest you get it from Tangent, whose prices are reasonable. Share this post Link to post Share on other sites
