ablaze 0 Report post Posted August 21, 2003 How do you all get by this? Often times, when A/Bing equipment, the equipment that "sounds" better is often the one that is simpler louder, even by 1dB. subjectively, they may sound like they're the same volume, but if you've got some objective testing equipment, eg. an SPL meter, you'll find that the two pieces of equipment you're comparing are simply NOT volume matched! Whats a good way to do this? I've tried measuring the output AC from the headphone output, in an attempt to match levels, but that doesn't seem to work ie. one still sounds louder than the other, even if they're both outputting 0.13V for eg. (whats the reason for this? different output impedances?) How do you all get by this? Don't you all wonder each time, say when you get a new amp, and it sounds so much better, if the "improvements" are simply cos you're not used to the volume control on the new amp/source/etc, hence you've just turned it up just a TAD louder than you're used to listening to, and hence..the usual "more details", "more air", "more slam", "more weight" impressions strike you? Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 I don't know if I should be using "loudness" instead of "volume" here Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 21, 2003 (edited) Most of the time, I merely use my ears and gauge the loudness of a passage with outburst (easier to discern IMO). For crucial testing of cans/amps, place the mic of spl meter in between the can's cups and playback a 1KHz tone for volume adjustment and mark the levels. Edited August 21, 2003 by Mackie Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 what if one source has an abnormally high/low production of sound in the 1khz range Share this post Link to post Share on other sites
mychew 0 Report post Posted August 21, 2003 i just try to adjust to the same volume when i tried different amps or headphones...this is what i learnt from Mackie Share this post Link to post Share on other sites
Blues 0 Report post Posted August 21, 2003 sometimes it's abit hard... esp for cans like 880 and cd3k cd3k needs like 7 o clock while beyer 9.. and sometimes even more. if you do it wrongly, will taint your impression Share this post Link to post Share on other sites
huangyong 0 Report post Posted August 21, 2003 true, the cans sometimes sounds not balance.. may be the transducer's prob??? or ...... Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 you guys seem to be missing the point. my question was not whether of not to MATCH the volumes (of course must match the volumes!) but HOW to do it most accurately Share this post Link to post Share on other sites
Wortel 0 Report post Posted August 21, 2003 with your ears? call yourself an audiophile do ya? Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 no. I don't want subjective loudness-matching. I want OBJECTIVE. and I don't call myself an "audiophile" Share this post Link to post Share on other sites
Wortel 0 Report post Posted August 21, 2003 Then whats the point of your tests then ablaze? Maybe you need equipment more like headroom. I looked down their site, wow was I impressed Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 Please don't talk rubbish in my thead wortel. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 21, 2003 (edited) what if one source has an abnormally high/low production of sound in the 1khz range U gotta have a cd containing a track with stable test tone of 1KHz (eg). I'm not sure if it's available commercially but certainly prevalent on the production lines. Otherwise, U can also download test tones from the internet and burn them onto CDR. With such tracks, a more accurate assessment of the volume output thru the amp and cans can be achieved. OT: It's a breeze to attain these tracks but the touchie is getting hold of a spl meter. Those sold in SLT are ultra expensive. I got mine from Perth for S$50 (thru a one-off deal and contact). U can also buy Radioshack SPL meter direct from US but it will cost U S$100. Edited August 21, 2003 by Mackie Share this post Link to post Share on other sites
ablaze 0 Report post Posted August 21, 2003 I don't get it. I tried with a 1khz test tone. matched both AC voltages identically. checked and double-checked. and yet, when I listen, I can tell one is still louder than the other. this is using the same headphones, and both unamped. urgh. Share this post Link to post Share on other sites
evil-zen 0 Report post Posted August 21, 2003 Levels were matched using the 1kHz test tone on the first Stereophile Test CD and measuring the AC voltage at the headphone jack with the Grados connected. http://www.stereophile.com/showarchives.cgi?617:2 something that i chanced upon. Share this post Link to post Share on other sites
