dreamie
Anyone built the Cmoy amp?
THe OPA134 on mine got hot.
anyway, i also tried to modify the circuit.
1) Removed input capacitor (save $$.. happy.gif blackgate too ex. blush.gif )
2) Output load resistor value is 49.9ohm instead of 50ohm to 100ohm.
3) LED using 150ohm resistor from positive and grounded to 0V (not 10K across +4.5 and -4.5). May need to change the resistor value if i decide to use 2x 9V.
Using the gold stereo jacks (female) u can get from Kaichin. $0.80 each.
Still in development stage. Size is about 1 3/4 of a 9V battery. headphone.gif
Hot... Is it still touchable?
I smell of the burnt smell soon after it was switched on. Only touched it after a few minutes of shutting down.
Nope. Seems like a short circuit.
You need to inspect carefully.
btw, i just realised i used 10k as the resistor to ground from pin 3 of OPA134. this wasnt the one i tested though.. this was the one i soldered. happy.gif .. i think this will result in louder sound..
I had OPA134 connect to +-12V but they don't get hot; just warm. Did you short the output to the ground, +V or -V? Really scare me.....
To get louder, should try changing higher value resistor between pin 2 and 6.
Heh.. i reckon it got hot because I did them on a project board and they oscillated.
Anyway, how would changing R2 (Pin 2 to ground resistor) to 10K from 100K affect the whole circuit? happy.gif thanks.
I you use non-inverting amplifier.
Gain = Rf/Ri + 1
Rf is the resistor between pin 2 and 6.
Ri is the resistor between Pin 2 and ground.
It's pretty difficult to get the OPA2132/ 2134 series of opamps to oscillate.
Guess you got a short or wrong connection on the opamp somewhere.
If you used dual voltage rails, you MUST connect the virtual ground (or PS ground) to the audio ground.
It's not advisable to change R2 to 10K unless you don't have a pot for volume control.
Gain = Rf/Ri + 1
Hmm.. according to this forumla i should be getting a gain of 2, if i followed the original one which used 100k, the gain would be 1.1. cool.gif
am i correct?
am i correct?
The resistor from Pin 2 to ground is NOT R2!!!
R2 is from In(+) pin to ground. ie. Pin 3 to ground on single-opamps!
am i correct?
