jtfoo
PPA made portable
Finally completed the PPA project. i.e. giving meaning to the middle 'P' of the PPA.
Actually doing up the battery board was much harder and health hazard than the amplifier board. Got myself cut in the process. But it's worth it.
I also have to build a external power supply unit(PSU) to give the non-standard 27Vdc. The PSU is based on Wellborne PS1 layout. There's slight variation in parts and I added a 1uF reservoir cap. Another variation is I added 24Vdc so the PSU can power the Meta42 too.
Some parts differences from the Wellborne are,
Rectifier diodes - Schottky diodes (BYV10-60). They have very low forwarding voltage. I measured them to be about 0.18V to 0.2V.
Snubber caps for diode, WIMA MKS3. 10nF
ELCO- 3X Elna ToneREX(2200uF) and 1x Elna Silmic(100uF).
Bypass - 0.1uF film cap from Rifa Evox,
Reservoir cap - 1uF polyester cap from Rifa Evox.
What made the PSU a audiophile PSU is the hot glue isolating the PSU board from the chassis. This reduce vibration and reacts with resonance in many good ways laugh.gif
The porn of the PPA with battery board.. Fast charging time suppose to be 2.3 hrs.. But initial fast charge took 3hrs 10 min to go into trickle mode.
And here's the charging in process with all LED lighting up,
I was about to buy them only to realise through ELNA's catologue that no such rating exists. Thus it got me wondering the genuity of the components.
Jialat.. Hope the ELCO caps won't blow .... But I'll leave them there just yet.
JAson,
I don't have the means to measure temperature... I'll try and see if those thermometer from the SARs kit can do.
Edited by jtfoo
Mine felt hot but touchable.
Had add 3 heatsink at the buffer and looks pretty, too bad no camera... dry.gif
That's alot of AAs!
The PPA needs all those AAA to give a decent voltage for the opamps to work optimally. With 15 cells, that's about 18V nominal, but can reach 21V for freshly charged batteries.
Hmmmm, after I adjust the voltage to 15V and the buffer becomes luke warm. This is important for portability as the hotter it gets the faster the batt used it's power. It also ensures the working life of the component.
Now doing some serious listening to determine whether the music becomes better or worse before I built the final power supply.
This would take sometime around december before I can complete both the AD8210 and the OPA637 version. tongue.gif
