adhoc
where to find tubes in singapore?
hello all,
just a simple question:
where can i procure 6AS7/6080 or 6SN7 tubes in singapore?
regards,
aaron
EDIT: also, any impressions/opinions on any tube in particular would be very welcome!
Edited by adhoc
Well, there are two shops in Bencoolen Street, Burlington Square selling tubes,
Martin Electronics
#01-47 , Tel - 63364420
and
Well Audio Lab
#01-123, Tel - 63380368
Im sry but i have no experience with the above tubes, but i did tube roll my Cayin HA-1A to Mullard 4004/4003 and JJ / EI EL84 Tubes...
More info can be found in this thread -Tube rolling the Cayin , courtesy of Mackie!
Hope this helps a little...
Hi Adhoc
I'm not familar with the 6AS7, but 6SN7 yes. Wil has already provided you with the sources.
Each tube has its own characteristics, but the one's which I prefer are the Sylvannia VT231. Frankie at Well Audio may also have some other exotic tubes which are interesting. Checkout those with the brown base. I hope you don't need many of these as they are expensive.
If you require a lot, I would instead consider current production by EH 6SN7, which actually isn't too bad. There is a lot of hype about NOS, some are good, some just don't cut it. Not everything NOS is good.
Which amp are you using it for?
eddie current hd-25. uses 1x 6SN7 and 1x6AS7/6080. happy.gif
fwiw, i already have managed to procure NOS raytheon and kenrad vt-231s and 1 of the famed sylvania 6sn7 brown bases (1952 vintage) - 3000/3050 and in mint condition! 252 date code. w00t w00t! party.gif
Edited by adhoc
