neutralzz 0 Report post Posted December 31, 2005 uncommon tubes.. radio toobs.. probably could either buy from overseas or check with martin/well audio. not many places in singapore have a decent range of tubes Share this post Link to post Share on other sites
squalle 0 Report post Posted December 31, 2005 hmm then I consider myself lucky choosing not to build millet Share this post Link to post Share on other sites
1bit 0 Report post Posted December 31, 2005 what's a suppressor? kippei, if you need money for the shipment of the millet boards let me know thanks Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 hmm then I consider myself lucky choosing not to build millet Nothing unusual about parts not being able to find. My ppa most of the stuff are imported by farnell and shipped in from USA Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 what's a suppressor? kippei, if you need money for the shipment of the millet boards let me know thanks I dont think we got the board anyway Share this post Link to post Share on other sites
kross 0 Report post Posted January 1, 2006 just finished testing the hybrid amp today. sounds good, quite a warm sound from the tube though i would love it to be warmer..:-) anyway, my problem now is to try to eliminate the slight soft hum from my variable power supply. does anyone has any suggestions to remove the hum? Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 Wat supply you using.... If it is those wall adaptor, add a TREAD in between Share this post Link to post Share on other sites
kross 0 Report post Posted January 1, 2006 yup, similar to those wall adaptor. does your TREAD refers to the tangent's TREAD? Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 Yesh... if you ever taken apart your wall adaptor. The crap inside is barely enough to deripple the line noise. So i mod it into like this. http://www6.head-fi.org/forums/showthread....ht=wallwart+mod Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 1bit stilll want to order the thingy Share this post Link to post Share on other sites
neutralzz 0 Report post Posted January 1, 2006 just finished testing the hybrid amp today. sounds good, quite a warm sound from the tube though i would love it to be warmer..:-) anyway, my problem now is to try to eliminate the slight soft hum from my variable power supply. does anyone has any suggestions to remove the hum? see if any power carrying line crosses the tube etc. try to isolate as far as possible cuz the hum you're hearing is probably a 50-60 ac hum that's common with tube amps. tubes are at times microphonic and pick up these unwanted freqs.. else add probably 50-100 ohms to the output may help reduce hum too. Share this post Link to post Share on other sites
Kippei 0 Report post Posted January 1, 2006 Updates to the tube hunt... Went to well audio. The boss has no idea about the tube model... Share this post Link to post Share on other sites
neutralzz 0 Report post Posted January 1, 2006 wahh frankie todae got opens? Share this post Link to post Share on other sites
squalle 0 Report post Posted January 1, 2006 same here I've got my SOHA up and running, however there's this hum quite irritating. for the supply, already using LM 317 and LM337 for the op-amp trafo has been put around 6in away. dang dunno wat's wrong hmm, maybe shield the trafo away using alu foil? Share this post Link to post Share on other sites
neutralzz 0 Report post Posted January 1, 2006 your tube standing straight or lying horizontal? Share this post Link to post Share on other sites
