haxyer 0 Report post Posted July 19, 2006 (edited) Yes that is correct connection model. it wont work on any input only on tape in, the speakers will have no sound. i also dont know why Edited July 19, 2006 by haxyer Share this post Link to post Share on other sites
afbug 0 Report post Posted July 19, 2006 Strange. But tape in got sound la? If so, good enough? You connect CDP output to LD2+'s input and then LD2+'s output to receiver's CD input = no sound from speakers? Remember to select the CD input button on your receiver. Or you can try the method I suggested to wil? Hopefully can work. I'm sure your receiver got a tape loop/output. Share this post Link to post Share on other sites
haxyer 0 Report post Posted July 19, 2006 ya no sound, only tape in got sound and its good enough. lol ya got tape output also, if i use the tape output, am i pre amping the LD2+ using the receiver ? Share this post Link to post Share on other sites
afbug 0 Report post Posted July 19, 2006 Sort of. Try connecting all your sources to your receiver, then use the tape out to your LDM+. This is the ideal set-up if you got multiple source and using speakers I think. If you use your headphones/LD2+ mainly, then use the config you're using now as I think that less components in the audio chain is better. Go direct from CDP to LD2+ and the rest is secondary. In theory wil can: Vinyl / Digital setup - > adcom 750 preamp - > LD2+ - > poweramp - > Speakers and headphones. This set-up adds the LD2+ in the loop and for me, I'll prefer the previous set-up I suggested as the LD2+ is not in the poweramp/speaker loop. And I also dunno the LD2+'s output is a line out or pre-out. In theory, it should be a line-out but I dunno la, sometimes amp designers can have funny ideas. These are the few hook-ups I can think of. You can ask those more into Hifi for advise for the best possible hook-up. Share this post Link to post Share on other sites
Mackie 0 Report post Posted July 20, 2006 (edited) Short signal path sounds best and so is the simple approach in connecting your setup. If you have a speakers system and also wish to listen to all your sources via a headamp+cans, connect the headamp to <tape out> of the pre-amp/integrated amp/receiver. Edited July 20, 2006 by Mackie Share this post Link to post Share on other sites
wil 0 Report post Posted July 20, 2006 I was told impedence matching ( esp in SS amps ), is impt when connecting the headamp to the tape out. Share this post Link to post Share on other sites
Mackie 0 Report post Posted July 20, 2006 (edited) Well, someone is pulling a fast one on you. Impedance matching is a key consideration between pre-amp and power amp as it affects gain. It's a prevalent standard that all line input has high impedance (47Kohms for solid state) and output has low impedance. This applies to sacd, cd, tuner, aux, line in/out, tape in/tape out etc. Edited July 21, 2006 by Mackie Share this post Link to post Share on other sites
wil 0 Report post Posted July 20, 2006 Ah....ok. Thanks for clearing that out. I didnt know it at first, but having the option of including my headphone amp into my speaker setup without removing any cables is a neat trick! Share this post Link to post Share on other sites
afbug 0 Report post Posted July 20, 2006 I didnt know it at first, but having the option of including my headphone amp into my speaker setup without removing any cables is a neat trick! No removing of cables, just add a pair of IC from tape out to LD2+ input and you should be able to enjoy both speaker and headphone set up. If your preamp have 2 sets of tape loop, lagi best! You can add another headamp or some other gadget! Waa lao, what I wanted to tell you can be summerised into 1 short sentence! Realised it after posting so much. lol. Share this post Link to post Share on other sites
neutralzz 0 Report post Posted July 21, 2006 I was told impedence matching ( esp in SS amps ), is impt when connecting the headamp to the tape out. i saw a headphone out on one of cary's 300b SETs.. not getting franky to mod a headphone out on the 2A3? :X Share this post Link to post Share on other sites
wil 0 Report post Posted July 22, 2006 (edited) I was told impedence matching ( esp in SS amps ), is impt when connecting the headamp to the tape out. i saw a headphone out on one of cary's 300b SETs.. not getting franky to mod a headphone out on the 2A3? :X I rather my Sun remain untouched.....lol. Edited July 22, 2006 by wil Share this post Link to post Share on other sites
