ablaze 0 Report post Posted July 24, 2003 mat, did you order a lite in the end? Share this post Link to post Share on other sites
matbon0013 0 Report post Posted July 24, 2003 No, because I was a little bit weary and unsure about this PSU issue, my preferrences with audio equipment with external PSU is as you would say very particular. I'll give this product a miss until Headamp.com comes up with a solution for our 230v mains. Share this post Link to post Share on other sites
ablaze 0 Report post Posted July 24, 2003 there's still a chance to cancel the pre-order and get a refund as long as it hasn't shipped what. Share this post Link to post Share on other sites
matbon0013 0 Report post Posted July 24, 2003 Yeah I was very tempted. But no thanks! Maybe I'll get bigger brother, who knows not now though! Share this post Link to post Share on other sites
antness 0 Report post Posted July 24, 2003 I have a step up / down transformer to simulate this the best that I can, and I havent found using a step down transformer to increase noise at all. I think that may just be speculation, have you had a problem with that in the past? Share this post Link to post Share on other sites
ablaze 0 Report post Posted July 24, 2003 justin, good to see you finally reply. Rameish has got some very relevant questions on page 2 of the thread http://www.sgheadphones.com/index.php?s=&a...f=2&t=675&st=15 please do address them. thank you. Share this post Link to post Share on other sites
antness 0 Report post Posted July 24, 2003 1) Cardas RCAs? Nope. The Gilmore Lite uses the same RCA jacks as the V1 and V2, they aren't made by Cardas but are just as nice and not insanely priced. 2) Volume pot - ?? Volume pot is the Panasonic often used in META42 3) Neutrik non-locking circuit mount headphone jack? Non-locking chassis mount jack, same as in Gilmore V2 4) Vishay-Dale resistors. Yes, just like the V1 and V2 Share this post Link to post Share on other sites
ablaze 0 Report post Posted July 25, 2003 antness, so other than enclosure, pot, different input/output ie. the 'lite' has only one input and one output, what other differences are there from the V2? (excluding the power supply side of course) Share this post Link to post Share on other sites
matbon0013 0 Report post Posted July 25, 2003 I have a step up / down transformer to simulate this the best that I can, and I havent found using a step down transformer to increase noise at all. I think that may just be speculation, have you had a problem with that in the past? Justin, yes I had problems pertaining to PSU issues before with other products. Share this post Link to post Share on other sites
ablaze 0 Report post Posted July 25, 2003 more specifically, mat? Share this post Link to post Share on other sites
pipee 0 Report post Posted July 25, 2003 One thing Ive decided to do is to lower the default gain on the Lite to 5, unless asked otherwise. This is because, as Rameish pointed out, the imbalance in the pot. antness, Can a gain of 5 drive the AKG501 and HD600 well? Share this post Link to post Share on other sites
erickoh 0 Report post Posted July 25, 2003 How about a gain of 8? I'm comfortable with that number Antness mentioned he's fine with selling the gilmore lite w/o the ELPAC PS. I personally find it cumbersome to use a step down into a 120V ELPAC. I'd rather use it with sealed lead acid batteries and charger. Should be quite maintenance free. Share this post Link to post Share on other sites
jtfoo 0 Report post Posted July 25, 2003 I personally find it cumbersome to use a step down into a 120V ELPAC. I'd rather use it with sealed lead acid batteries and charger. Should be quite maintenance free. The Gilmore needs + & - 15V or so. You'll need to make a simple voltage splitter circuit if you want to use batteries. Nearest would be splitting a 24V battery (2X12V battery)into +&- 12V. Share this post Link to post Share on other sites
ablaze 0 Report post Posted July 25, 2003 eric, if you want the gilmore without the elpac, you gotta tell me so I can officially change the order. cos by default it'll come with the elpac. same goes for the gain setting. by default it'll be 5. Share this post Link to post Share on other sites
erickoh 0 Report post Posted July 25, 2003 Are you guys getting the ELPAC despite antness not being able to procure the 240V version? I am just wondering if there is another equally good PS that's available locally. (Do tell if anyone knows) As for batteries.. antness suggested using 24xAA batteries. I was thinking the gilmore lite is able to take from 15V to a little more than 24V Share this post Link to post Share on other sites
