loop_ 0 Report post Posted September 2, 2007 Hi, Am currently sorting out my casing for the beta22 im building. Was drilling holes when I stupidly pressed the back panel against the newspaper, and all the metal shavings started scratching it. So now it looks very very beat up... Any ideas on how to unscratch/heal/hide those damn blemishes? Am very open to 'creative' ideas. thanks in advance Share this post Link to post Share on other sites
Fuzzy Fuzzbucket 0 Report post Posted September 2, 2007 thats abit impossible now. black dye are sort of fused into the aluminium and followed by artificial anodising, creation of the thin but dense layer of protective aluminium oxide... i tried colouring with a permanent marker and then cleaned off the access... Share this post Link to post Share on other sites
heady 0 Report post Posted September 3, 2007 Hi, Am currently sorting out my casing for the beta22 im building. Was drilling holes when I stupidly pressed the back panel against the newspaper, and all the metal shavings started scratching it. So now it looks very very beat up... Any ideas on how to unscratch/heal/hide those damn blemishes? Am very open to 'creative' ideas. thanks in advance Sadly, been there, done that. The only way I can see, is to sandpaper the metal until very smooth and then spray paint. I thought I could cover up the small nicks with spray paint but it didn't. Need to smoothen before spray. I usually put a layer of masking tape when drill but the metal chips also cut right through that. DIY is a series of expensive lessons. Every time someone says to me that looks good, they don't know how much I had to pay for tuition. Share this post Link to post Share on other sites
loop_ 0 Report post Posted September 3, 2007 next time i'm just going to a shop and ask them to drill everything for me...basket... anyway i decided to just follow fuzzy and draw with permanent marker..now instead of silver lines i have black ones. ugly but abit less ugly la.. Share this post Link to post Share on other sites
aegisofrime 0 Report post Posted September 3, 2007 I think I might be able to help you with this. Firstly what I was thinking is to remove the paint or sand it out. Later airbrush it with some metallic paints and buff it until you get the brushed metal look. I have done this with my Gundam kits before and it looks quite good. Problem is I don't have any experience with airbrushing on metal. Might have to airbrush on some metal primer first or else the paint won't stick. Share this post Link to post Share on other sites
Fuzzy Fuzzbucket 0 Report post Posted September 3, 2007 i was thinkin of sanding down too. oh well... have you cleaned off the access? so your're left with only fine black lines? Share this post Link to post Share on other sites
heady 0 Report post Posted September 3, 2007 There is another solution - which I am thinking of trying for the Mini3 panels. Have a plastic one which goes infront of the metal panel. It is stuck on with glue. This is done by the plaque people. Share this post Link to post Share on other sites
loop_ 0 Report post Posted September 4, 2007 (edited) hey thanks for all the tips and aegis for your offer. But I just took the lazy man's solution. A bit childish i.e. don't like what you see just use magic marker. at the end of the day, it's just a back panel la, cannot be too sad. Maybe I'll try sanding/painting it if I ever choose to sell it. Basket this project taking so long with parts missing here and there don't even know if it'll run or explode... Edited September 4, 2007 by loop_ Share this post Link to post Share on other sites
aegisofrime 0 Report post Posted September 5, 2007 Hey its a Beta22 supposedly the king of DIY amps... I'm sure its worth the effort. Share this post Link to post Share on other sites
