snowparang
Recommend mp3 software player
hi gurus, may I know what mp3 players do you use? Anybody did a test on these 3 or others?
I personally find kernel streaming (foobar2k) the best, using my onboard sound and cheap BEhringer headphones.....
Also, where to get the ASIO plugin for Winamp? Winamp -> kernel stream = how?
I have put the Asio dll for winamp version 2.XX on my geocities site to make it easy for me to link too. www.geocities.com/fuzzey_door/winamp-asio.zip
Just put the dll into the "winamp\plugins\ " directory and it will turn up in the preferances for output plugins.
Be warned however that not all soundcards have asio support.
Rgds,
press ctrl-p in winamp3, select 'directsound' on the left. enable checkbox that says 'enable directsound output'.
Using Winamp 2.xx with MAD plug-in and Waveout is pretty much better than the default Winamp plug-ins.
Coolplayer isn't shabby either. Matching up to the above while being less of a resource hog.
Testing out Foobar now. Ain't too bad. smile.gif But I'm not a MP3's freak...
