Guest kerss
best headphones to buy?
Guest kerss
What is the best headphones (the ones that covers your whole ear) to buy with SGD$160 in Singapore???
Btw im new here...
Edited by kerss
grado ms-1. haha.
i'm a grado-holic. once you love the grado sound, its hard to go for others. but i must say, thy;re not that easy to match with clothes.
grado, not good for on the go right? as in not at an advantage. You mostly listen to what genre of music? and budget(range can do)? oops, if i am to frank.
From there, we can tell =)
grado ms-1. haha.
MS-1 should be Alessandro, not Grado. ;) About matching clothes, don't worry, fashion goes retro now and then. :D
Guest kerss
i listen to any kind of music actually.
i usually listen to music with strong base.
Edited by kerss
for way below the 160sgd budget, go for the Senn HD201. good sealed isolation from the circumaural fit, easy to drive plus light enough for portable use. u get some loose change on top of that.
Edited by sghound
You may want to consider the Audio Technica ATH-ES7
It is comfortable to wear and light weight, foldable in a way you can easily store in your bag.
Edited by Stereo_Electronics
wanted to suggest this but it's more than his budget?
Edited by sghound
Guest dragonboy
top up another $29 on your budget and go for the ES-7. Grado or alessandro sucks on isolation.
