Rules & Regulations - please read!
GalleryArcade Help
Search
Members
Calendar
| zer061zer0 |
14 Jun 2007, 09:46 PM
Post
#1
![]() Very Senior member ![]() ![]() ![]() ![]() ![]() Group: Senoir Member Posts: 332 Joined: 8-July 06 Member No.: 2,510 |
With a little free time and having read quite a bit on modding the Grado phones, I have decided to go about trying the mods I have read.
I am still in the midst of doing it but decided to post some pictures of the inital stages of doing it. Pictures are taken by my girlfriend. I will update the first thread as I complete the whole mod but meanwhile do give me some inputs such as the sort of cables to use, better alternatives and suggestions like that. This is my SR80, which I have gotten from a trade. Despite possessing the grado sound, but its no where near the likes of MS2i or SR225. Can't really compare them this way as they are of different value and I understand that they have different construction, voice coil and etc. So hopefully this mod would better improve it. ![]() First up is the headband. It can be remove rather easily by pulling the 2 grip holding onto the driver unit. Pull out each side one after the other. ![]() Then its the driver unit. Removing the casing basically open up quite easily, I tried a few methods but it seems that the heat and spoon method used simultaneouly is the best. Heat the the cans from the side for a few mins, followed by pushing a spoon across the groove and you got the cans open. Too bad I do not have pictures of the process but this is basically what I used to open them up, a hairdryer and a spoon. ![]() This is the grill side with the cover, grill and enamel removed. Similarly the grill can be removed with a little heat and some pushing. ![]() Removing the enamel from the grills, would probably keep them. ![]() The buttons and the driver side, easily removed with a few pressing using my hands. ![]() ![]() That's all as of now, I have just gotten the mono jacks, 2.5mm ones but i am still thinking if i should use a 3.5mm stereo on one side. Anyone tried such mods before do share with me and the rest. Will post again soon. -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
Preamps, Amplifiers:Modded Xiang Sheng 708B, Crossroads 2, FIIO E3, DIY Headphone Amp with USB/DAC, CMOY2, Cobra D10, DIY 6L6 Tube Amp, LittleDot MK V, Topping TP21 Earphones, Headphones: Crossroads HR2, UM Triple Driver Customs, Beyer DTX20, UE Metrofi 220, Astello Radiance+, Hippo Boom, Modded Grado SR80, Sennheiser PMX70 & HD580(recabled), Audio Technica ANC7, AKG 240M & K501, Koss Porta Pro (BlacK), KSC75, Modded KSC75 Multimedia Speakers: Creative T20 Speakers: Looking for something... Previously owned: Creek 4040, T.S Audio SE34.1, Carver CM1040, Onix SA60, DIY Fostex FE103, Albarry PP1, Lecson Quattra, QED A240CD, Goldring DR150, AKG271, Lite DAC-AH, Modded Marantz cd63, Philips DVP3020, Creative Stone, Creative Zen, Zero DAC/Preamp/Headamp, CK2III, SOHA, Philips SHP895, Grado MS2i, Cyrus I, Crossroad Mylarones, DIY LM3886, Xiang Sheng HA02, TMS-5(EL84 tube amp), Topping TP10 MK3, Little Dot T200, AUNE DAC/Headamp, Soundmagic PL20, Usher 520, Custom Bookshelf Fullrange, HD 280, Swans S3W, Altec Lansing MX5021 Clearing out my closet Sales Thread My Feedback Thread VR Forum Referral Link |
| zer061zer0 |
15 Jun 2007, 03:22 PM
Post
#2
The mono jacks gotten yesterday was the wrong size and couldn't fit very well.
Instead I rewired it to be on a one side. Didn't really have the photos of the work in process as there was a lot of filing involved to fit the plugs in. This is how the jack looks like in the driver unit, now that its on one side(left) I have to wire over to the right driver over the headband. ![]() A bottom view of the jack itself, this section require quite a bit of filing on the casing to fit it just nice. ![]() The right driver unit. ![]() The left driver with the stock cable reterminate on a 3.5mm jack ![]() The sound did change a little, I feel that there is an increase in clarity, in fact I hear certain things more clearly then i did before the mod. Like background hiss for a particular track and also breathing of the guitarist in another. But i am suspecting that this might be due to the fact that i have no grills on now There is also slight widening in the soundstage, and there seems to be added depth to the stage. I am very sensitive to the soudnstage so thats the first thing that i noticed. But the depth thingy is quite subjective. However the bass was little lesser then before. Really hope anyone who have done anything similar before could share some advice or opinions. And now that its done it will be good if someone can recommend me some cables that goes really well with grado phones. PS, I do not really know how to describe what you hear and normally i judge it by the staging and the "feel" u get from the music. Therefore my opinions are purely personal views of it. -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
| zer061zer0 |
21 Jun 2007, 04:04 PM
Post
#3
A new grill and new cables
![]() A closer view, I must say that the neutrik 1/4 inch are rock solid looking. Grills are those taken off the computer heatsink fan, and the cables used are Canare starquad, with neutrik jacks. ![]() Grado modded phones with my amps, Xiangsheng and CK2III ![]() Another look at the phones with the quarter mod on the pads, the next thing would be the padding on the headband ![]() -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
| Stereo_Electronics |
21 Jun 2007, 10:08 PM
Post
#4
![]() VIP Dealer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Audio Dealer Posts: 1,838 Joined: 18-August 05 Member No.: 1,856 |
Nicely done, finally a grado mod with decent pictures.
Just curious, I tried the starquad canare but felt the orginal grado sounded better, what about you? The canare starquad sounded rather lean to me and harsh on louder music. You make me want to strip my grado again.... -------------------- Stereo Electronics Pte Ltd - 1, Woodlands Square Causeway Point Shopping Centre, #04-08/09/10 Tel:68943601 - 68, Orchard Road Plaza Singapura #04-06 Tel: 63367113/63367114 Open daily 11.30am - 9.30pm www.stereo.com.sg & Hardwarezone Headphone forum stereo electronics facebook account |
| loop_ |
22 Jun 2007, 01:28 AM
Post
#5
Junkie ![]() ![]() ![]() ![]() ![]() ![]() Group: Senoir Member Posts: 408 Joined: 28-August 05 Member No.: 1,885 |
nice grills. looks really different, but i think i still prefer the grado 'retro' look.
do a review of your diy amp! |
| zer061zer0 |
22 Jun 2007, 10:15 AM
Post
#6
Nicely done, finally a grado mod with decent pictures. Just curious, I tried the starquad canare but felt the orginal grado sounded better, what about you? The canare starquad sounded rather lean to me and harsh on louder music. You make me want to strip my grado again.... Do try it out, I do share some similar sentiments, sort of lesser extension (less echoy) not sure how to describe that. What cable have u tried? nice grills. looks really different, but i think i still prefer the grado 'retro' look. do a review of your diy amp! I would love to but its gonna takes a while as I am rather busy these days. -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
22 Jun 2007, 12:03 PM
Post
#7
On the SR60 and 80 I've tried Canare, Belden, Mogami, QED, AudioQuest, Klot and a lot of old cables I dig out from my storeroom... I should do it again, this time I'll tried to look for something rare and unusual.
| PPkiller |
22 Jun 2007, 12:07 PM
Post
#8
Senior Member ![]() ![]() ![]() ![]() Group: Senoir Member Posts: 211 Joined: 1-April 07 Member No.: 3,407 |
paper clip? :-x
-------------------- Laptop(Dell 9400) -> Ibasso D1(HT6241-> AD743-> LME49600) -> HD 650
22 Jun 2007, 01:12 PM
Post
#9
paper clip? :-x I will consider that when I decide to mould the headphone to my head. -------------------- Stereo Electronics Pte Ltd - 1, Woodlands Square Causeway Point Shopping Centre, #04-08/09/10 Tel:68943601 - 68, Orchard Road Plaza Singapura #04-06 Tel: 63367113/63367114 Open daily 11.30am - 9.30pm www.stereo.com.sg & Hardwarezone Headphone forum stereo electronics facebook account |
| zer061zer0 |
22 Jun 2007, 01:55 PM
Post
#10
On the SR60 and 80 I've tried Canare, Belden, Mogami, QED, AudioQuest, Klot and a lot of old cables I dig out from my storeroom... I should do it again, this time I'll tried to look for something rare and unusual. I was looking at the cable the other and realise that the stock cables is in fact very thin. i did terminated a mini plug to the stock cable in case i wanna play ard with it. How is the klotz, starquad too i presume. How abt the belden and mogami, what models are they. -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
22 Jun 2007, 05:16 PM
Post
#11
Mostly starquads. Never underestimate the performance of small size cables, lots of high performance audio cables are not very thick, like my recent favourite crystal cable.
![]() Cystal cable interconnect -------------------- Stereo Electronics Pte Ltd - 1, Woodlands Square Causeway Point Shopping Centre, #04-08/09/10 Tel:68943601 - 68, Orchard Road Plaza Singapura #04-06 Tel: 63367113/63367114 Open daily 11.30am - 9.30pm www.stereo.com.sg & Hardwarezone Headphone forum stereo electronics facebook account |
| aloy |
22 Jun 2007, 05:20 PM
Post
#12
Very Senior member ![]() ![]() ![]() ![]() ![]() Group: Senoir Member Posts: 388 Joined: 20-August 06 Member No.: 2,655 |
another case of not judging a book by it's cover?
| zer061zer0 |
22 Jun 2007, 07:47 PM
Post
#13
Mostly starquads. Never underestimate the performance of small size cables, lots of high performance audio cables are not very thick, like my recent favourite crystal cable. ![]() Cystal cable interconnect actually i have been very interested in trying out silver cables, but have yet to find a cheap source. Whats the cost of this Crystal cable? I was just wondering, how do u spread the cables in a star quad connection. 1L, 1R, 2 G or 2l, 2r, shield as gnd. -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
| Fuzzy Fuzzbucket |
16 Jul 2007, 11:42 PM
Post
#14
![]() Member ![]() ![]() ![]() Group: Senoir Member Posts: 127 Joined: 12-July 07 From: Woodlands Member No.: 3,628 |
nice nice but do u want to change those nickle plated steel grilles to aluminum or stanless steel ones???
those nickle steels won't stay that shiny for long... -------------------- если оно не сломано, то не зафиксируйте его Быть или не быть? чей вопрос то? определенно не шахта... |
| zer061zer0 |
6 Dec 2007, 04:37 PM
Post
#15
Actually they are still shiny untill i have deicided to remove them..
listen to the modded ms1 at stereo sort of put my works to shame.. Anyway I have done some new recabling and the earcup but still not satisfy with the look and sound. Some updates to my SR80... recabling to both side with a slightly stiffer wire and added some new design to my earcups, but still unhappy.... ![]() ![]() This post has been edited by zer061zer0: 6 Dec 2007, 04:38 PM -------------------- Sources: Asus K40IN, Meizu M6SL, iPod Classic, iPod Touch 2Gen, Dugood HDV-2800, LittleDot CDP I and DAC II, TDA1541 DAC
Lo-Fi Version | Time is now: 31st July 2010 - 08:47 PM |
