tropicalrips 0 Report post Posted November 12, 2003 anyone knows how to build a discharger for a single 9v battery? i need a simple circuit to discharge the 9v batt used in a Cmoy before recharging it, can anyone help, this should be quite simple for u guys Share this post Link to post Share on other sites
lekguan 0 Report post Posted November 12, 2003 I think if you use Ni-MH you don't have to discharge. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 12, 2003 its Ni-MH but i think its still safer to discharge them before recharging, they are not cheap i'm looking for something thats more "high end" not just a row of light bulbs to drain the 9v i think the battery will last longer if we discharge them to a certain voltage before recharging, it will also make them perform better (learn this racing RC cars high performance 7.2v batt) Share this post Link to post Share on other sites
jtfoo 0 Report post Posted November 12, 2003 (edited) I also think there's no need to discharge first and no damage will be done. You should be more concern of overcharging, which is more damaging. Read thru this site about memory effect.. http://www.dansdata.com/gz011.htm Edited November 12, 2003 by jtfoo Share this post Link to post Share on other sites
evil-zen 0 Report post Posted November 12, 2003 hmmm why don't u use them in your cmoy until flat? that's what most people do anyway. Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 12, 2003 I also think there's no need to discharge first and no damage will be done. You should be more concern of overcharging, which is more damaging. Read thru this site about memory effect.. http://www.dansdata.com/gz011.htm i think i should throw away what i know from RC racing we always discharge our cells to get the max punch from them, and we use up the 2000mAH in 5mins, u can cook an egg on the batt when its fully drain from a race guess that doens't work for Cmoy Share this post Link to post Share on other sites
Q00 0 Report post Posted November 12, 2003 what i learn for rc racing also got stuff about overcharging also... but then i had this charger that kept it from overcharging... Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 12, 2003 turbo-thirty? it can charge the cell indivigually its also a discharger has a printer to print a report on the cell perforamce during the charging/discharging process but it will also burn a big hole in your wallet Share this post Link to post Share on other sites
jtfoo 0 Report post Posted November 13, 2003 Here's some Battery FAQ link, http://homepages.paradise.net.nz/ianjenki/faq.htm This one is for Nicd, but many point are still relevant for NiMH. http://www.repairfaq.org/ELE/F_NiCd_Battery.html http://www.repairfaq.org/ELE/F_NiCd_Memory.html Share this post Link to post Share on other sites
Rameish 0 Report post Posted November 13, 2003 hmmm why don't u use them in your cmoy until flat? that's what most people do anyway. Keep doing this constantly and you'll need to replace your drivers as well. Share this post Link to post Share on other sites
Rameish 0 Report post Posted November 13, 2003 Can damage your drivers as the voltage flux - ask firefox - he told me not to do it - something about an amp can output vdc when it's unstable (or the op amp is unstable). Anyways it made sense in another way - the amp goes into clipping as the battery dies. And clipping is very very bad for drivers. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted November 13, 2003 Hmmmm, if let's say 2 batteries are in series and one of it dies. What happen is the other battery that is still alive and starts to charge the one that is flat; making it reverse polarity. After charging the flat battery in negative polarity for awhile, the flat battery will now come back to life and start discharging again. If the cycle goes on and on, it will create an oscilating voltage supply instead of DC. Or the so called fluctuating voltage..... Is my theory correct??? Share this post Link to post Share on other sites
tropicalrips 0 Report post Posted November 13, 2003 sounds rite jason anyone with another theory? so the 2 9v design is not safe? and it works best only when the batts are matched? Share this post Link to post Share on other sites
N@Z 0 Report post Posted November 13, 2003 Can damage your drivers as the voltage flux - ask firefox - he told me not to do it - something about an amp can output vdc when it's unstable (or the op amp is unstable). Anyways it made sense in another way - the amp goes into clipping as the battery dies. And clipping is very very bad for drivers. My META amps are unlike the PCII the do not clip when voltage drops. The amps completely cuts out the sound when voltage drops to 6v & below. A drag though having to discharge/recharge the battery after that hence where plainviews would work great in this case. Share this post Link to post Share on other sites
