Fresno bob 0 Report post Posted May 5, 2005 It might. shorter runs are always the best but very hard to do plus it depends on the case you will put the moy in. i'm sure some of the more advance builders here can add to this. Share this post Link to post Share on other sites
siriuz 0 Report post Posted May 5, 2005 sounds like what i got too.. i fixed it by using 2 x 9v instead of one. it works with a fresh 9v too, but then after the voltage drops, i get this "whee" sound.. isit just me and starushz ? Share this post Link to post Share on other sites
Fresno bob 0 Report post Posted May 5, 2005 I really wont be able to tell if it only yours till i build this verson on some of the other versions its one the two problems listed. then again you could just have a ground wire thats not soldered good enough. also i have a question is there an alternative to using the LM6171 other than using caps. just wondering if there was another version or maybe another company made one close to LM6171. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted May 5, 2005 Should not affect. The whee sound is like oscillation. Did you clean the flux away? Share this post Link to post Share on other sites
heady 0 Report post Posted May 5, 2005 Sounds like RF. do you hear radio stations or any thing other than the music thats playing and this whee sound. other wise it might be oscillation. I have made many cmoys and other amps and had never had RF picked up. Most of the problems are due to bad contact between some components or poor solder joint or not following instructions correctly. One particular problem is the poor contact of the ground of the input plug and jack. And it can cause the squealing sound you mentioned, due to oscillation of the opamps. If you turn the plug in the jack and it causes this problem, then this is probably it. Sorry, I can't explain better in tech terms cos I am not EE trained. Share this post Link to post Share on other sites
Fresno bob 0 Report post Posted May 5, 2005 (edited) could any of these be use in place of LM6171 LM6181 OPA627 AD8610 AD8605 OPA134 AD843 Edited May 5, 2005 by Fresno bob Share this post Link to post Share on other sites
Guest starushz Report post Posted May 6, 2005 hmm..might be the LM6171 oscillating.Too bad no oscilscope to check. Will try with shorter wire today. Yup all cleaned up. No flux. Share this post Link to post Share on other sites
skyskraper 0 Report post Posted May 6, 2005 can you developpers PLEASE post the schematic the board is manuf'd from. virtual ground (ie: lm6171) info http://tangentsoft.net/elec/vgrounds.html Share this post Link to post Share on other sites
Guest starushz Report post Posted May 6, 2005 Guys one thing to ask. If we were to put the cmoy into a tin then the jacks must all be insulated right? If not hte Tin would be at the virtual gnd voltage. Or is it of not a concern? Share this post Link to post Share on other sites
heady 0 Report post Posted May 6, 2005 Guys one thing to ask. If we were to put the cmoy into a tin then the jacks must all be insulated right? If not hte Tin would be at the virtual gnd voltage. Or is it of not a concern? One of the gurus earlier in this thread had say there's no problem with the output signal ground in contact with the input signal ground. I think the VG is also connected to the output signal ground under the LM6171 socket. So looks like not a problem. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted May 7, 2005 To replace LM6171, you must use single opamp IC, like OPA134. Too bad OPA134 does not have enough juice to drive virtual ground. The battery I normally use are alkaline or NiMh. If your amp oscilate, try this. Connect the input first then power up. Wait for 5 sec then insert the headphone jack. Virtual ground circuit. Share this post Link to post Share on other sites
Fresno bob 0 Report post Posted May 7, 2005 jasonhanjk any op-amp thats single not dual can replace Lm6171 if so how much juice should it be able to handle Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted May 7, 2005 LM6171=90mA LM6181=100mA OPA627=100mA AD8610=65mA AD8605=cannot use OPA134=40mA AD843=50mA I just look through theis datasheet. The next few opamp that you might consider is 6181 and 627. No guarantee they will work though. Share this post Link to post Share on other sites
siriuz 0 Report post Posted May 7, 2005 BUF634P works as well i just tried it out, i *think* it sounds a little clearer i'm still waiting for my AD8066.. then i'll do some comparison between the AD8066s and the OPA2134s Share this post Link to post Share on other sites
alvin2038 0 Report post Posted May 9, 2005 can anyone explain the diff between the opa2227 and opa2228? from what i can see from the datasheets, opa2227 bandwidth is 8mhz, 2.3v/µs while the opa2228 is 33mhz, 10v/µs. from my earlier tests with the opa2228's, i reported some bad distortion with the bass esp at higher volumes. i replaced the opa2228's with opa2227's and there is no distortion now. could the distortion be due to the bandwidth of 33mhz? the opa2134 is also 8mhz. anyway, i'm really enjoying the amp with opa2227's. nice! Share this post Link to post Share on other sites
