johanjr 0 Report post Posted August 23, 2005 Ok, change them back to the original and short the 2 input cap. That should give no bass roll-off. i've put it back to gain 6 and after awhile realised what was the prob. the cable attached to the croc clips were loose with only a few strand attached.wondered why it didn't come off completely.anyway its in the hammond box already until i reliased that the i/o stereo conn is to big for the box.so i'll have to wait till weekend for a trip to slt. Share this post Link to post Share on other sites
johanjr 0 Report post Posted August 28, 2005 (edited) Finish off the cmoy2 but getting problem with oscillation. Reading the thread i've found that starushz and alvin 2038 also having the same problem. I'm using opa2228 also. ordered opa2134 to test whether its the ic thats having the prob. Funny thing is unless i on off/plug out HP, the cmoy2 sounds great. Put it back and i'll get hissing, occillation and a bunch of other noise Edited August 28, 2005 by johanjr Share this post Link to post Share on other sites
xchagg 0 Report post Posted August 28, 2005 The OPA2228 is a fast IC, so that might be causing the oscillation problem. The OPA2134s are slower, so if it's the 2228s causing the oscillation than your problem is solved. Also, have you tried removing the LM6171 and shorting pins 2 & 3 to see if the oscillation is still present? Just a shot in the dark haha, but that's one of the things I tried when troubleshooting my CMOY2. Turned out I snipped off the ground pin on the audio jacks by mistake so my IG and OG signals were going nowhere lol. Share this post Link to post Share on other sites
johanjr 0 Report post Posted August 30, 2005 hi guys opa2134 - lm6171 = no distortion....but occil abit then fades off...the sound continues nicely opa2134 + lm6171 = distortion opa2228 - lm6171 = distortion opa2228 left side = ok opa2228 right side = ok opa2228 + lm6171 = distortion opa2228 left side + lm6171= ok opa2228 right side + lm6171 = ok will double check the soldering tomorrow..sigh Share this post Link to post Share on other sites
skyskraper 0 Report post Posted August 30, 2005 have u tried swapping out the lm6171? id like to help more but after many requests it seems they don't want to post the schematic. ahhh the spirit of diy! i am sure once that is posted there will be more people who would be able to help you out. Share this post Link to post Share on other sites
heady 0 Report post Posted August 30, 2005 johanjr, if you have digicam, take pics of both sides of board. That helps a lot for the people who knows to help you. I think you have a solder join somewhere as I use OPA2134 and LM6171 with no problems. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted August 31, 2005 Oops... Posted at the first page liao, forget to update here.... Share this post Link to post Share on other sites
mormegil 0 Report post Posted August 31, 2005 anyone knows whether this amp is suitable for the er6i? Share this post Link to post Share on other sites
monsieuroctagon 0 Report post Posted September 5, 2005 I'm interested in doing this project. When can I get the PCB? Share this post Link to post Share on other sites
1bit 0 Report post Posted September 5, 2005 hi monsieuroctagon, you can buy the pcb from tropicalrips for S$11 each. i just bought one from him myself last week, and currently doing the project you can contact him through PM btw, guys can you tell me what is the value for the potentiometer? is it 10k or 50 k? how does it make a difference? Share this post Link to post Share on other sites
monsieuroctagon 0 Report post Posted September 5, 2005 can someone make this a little easier and post a compiled list of all of the parts to order from farnell or mouser? also, does the potentiometer already have a switch built in, or do I need to put on on the battery circuit? Share this post Link to post Share on other sites
heady 0 Report post Posted September 5, 2005 also, does the potentiometer already have a switch built in, or do I need to put on on the battery circuit? I used a pot with built-in switch to minimise usage of the panel real estate. The panel of the recommended casing is very limited in space. If you get the switched pot, you cannot solder it to the PCB as it is intended for only the non-switched pot. Share this post Link to post Share on other sites
monsieuroctagon 0 Report post Posted September 6, 2005 is there a case large enough that will accommodate the switch and dial at the front, the battery, and two 1/4 inch jacks in the back? If that's not going to fit, I suppose I could have the two cables hanging off the back. Share this post Link to post Share on other sites
magicpocket 0 Report post Posted September 11, 2005 Is the recommended pot 10k logarithmic or linear? Thanks in advance. Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted September 12, 2005 The case that is recommended is at the first page. I recommend mounting the led, volume knob and switch at the front panel, the in and out stereo jack will be at the side. Near the LM6171 IC. The pot is 50k log. Share this post Link to post Share on other sites
