jasonhanjk
Guide to fix up a Cmoy 2
Ermm...sorry, noob question, but the cmoy 2 is basically a portable amp, right? Anyways, could you PM me too? Thanks.
I finally got around to finishing my CMOY2 that I have had the parts for what seems like forever. I was really nervous when I put it together, but it worked on the first try!
So far it doesn't sound too bad. I'm impressed. This is my first headphone amp so I have nothing to compare it to.
I don't have a digital camera, but I will try to post pics soon.
Thanks go out to tropicalrips and Jason for all of your help.
How would I go about wiring a closed circuit DC jack?
Tangent's directions
Go down a ways until the pic of the jack. I understand the battery V- and Wall V-. Where do I hook up the two positive wires?
Edited by dbwinger
The 2 positive are short together.
So I solder both of the positives to the same lug on the switch?
Also, would there be any advantage to using polypropylene caps (I know they will be a little bigger) instead of the Wimas?
Has anyone built this using the LM6171?
If so, what are your impressions of the amp?
I am wondering if this amp sounds better with the LM6171 or additional Wima caps?
Can plug the ad8620 directly into the amp after converting to DIP?
Also OPA2107. Is there any changes needed?
Which opamp are good for ms-1
Edited by Kippei
Got mine up to go on the first try!!
But there's too much bass...roll off the cliff
soundstage sounds narrow
resistor i change the value abit
10 = r1/r5
100k = r2/r6
20k = r3/r7
20k = r4/r8
20k = r9/r10
are these the problems?
anyway i can improve it?
thanks
Can use this? It is a single unit pots... The rest are all out of stock
Whats is the difference between single and dual pots
Single unit pot will control volume for only one channel, ie left or right and not both. So definitely not usable for a stereo amp. For controlling volume on both right and left, you need a dual unit pot. If you are in SG, the only place selling dual unit pots is Farnell (as far as I know).
You also need the dual log to be audio taper or also known as logarithmic. The linear pot which is more common is not advisable for audio use.
But you can order from Tangentsoft, only problem is, you need to order more than 1 pot to make the order cost effective. You can always order PCBs.
10 = r1/r5
100k = r2/r6
20k = r3/r7
20k = r4/r8
20k = r9/r10
thanks
Hi.
You should try these value to reduce the bass rolloff.
R1: 10
R2: 20k
R3: 20k
R4: 20k
R5: 10
R6: 20k
R7: 20k
R8: 20k
10 = r1/r5
100k = r2/r6
20k = r3/r7
20k = r4/r8
20k = r9/r10
thanks
Hi.
R1: 10
R2: 20k
R3: 20k
R4: 20k
R5: 10
R6: 20k
R7: 20k
R8: 20k
hi jason
tried it but it sounded funny....i get weezing sound when i touch any of the resistor.the resistor is mounted on the socket so i can play around with gain and such.
going to resolder the wires with those multi strand wires. was using the single core type and it seem to come off 1 by 1. progress abit slow though
