Yon 0 Report post Posted August 6, 2005 Do they work on headphone cables too? 1 on each ends.... Share this post Link to post Share on other sites
[J]-ohn 0 Report post Posted August 10, 2005 Certainly, just as they work for normal hifi equipment to reduce hiss and noise due to the EM and RF interference. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 10, 2005 I suggest not to use ferrite clamps on interconnects and headphone cables as they tend to stifle dynamics and thus resulting in a dull sound. Treble extension also suffers. However, these detriment may be less noticeable and even beneficial when used on power cords. Let your ears decide. Share this post Link to post Share on other sites
skyskraper 0 Report post Posted August 10, 2005 clamps are so cheap, even if you don't like it on your headphones it wont be a huge out of pocket expense. Share this post Link to post Share on other sites
huangyong 0 Report post Posted August 10, 2005 yea, agree with Mac, they are good for power cord. If you are naughty enuff, just open your amp to clamp it at the transformer wires. It helps a lot in reducing noise. Share this post Link to post Share on other sites
[J]-ohn 0 Report post Posted August 12, 2005 I have a question..... Since ferrite clamps only have direct effect on RF and EM interference in the cable, how does the orginal signal get altered during this process? I always thought its either you get an improvement from the clamps or get nothing (if there is minimum interference in the cable or system), didn't know clamps could technical cause a change in the orginal music source. Share this post Link to post Share on other sites
Mackie 0 Report post Posted August 19, 2005 ho ho ho...U are questioning an area where the knowlege is gonna technically challenging and intensive. I recall a member by the nickname of fishball79 wrote a price on this. Otherwise, google search "cable skin effects" or "cable dielectrics" and U will learn much on how the material and method of "housing" a cable conductor can have effect on sound. Share this post Link to post Share on other sites
chow 0 Report post Posted September 24, 2005 where to get ferrite clamps? good 1 Share this post Link to post Share on other sites
Stereo_Electronics 0 Report post Posted September 24, 2005 We got TDK ones.... Share this post Link to post Share on other sites
chow 0 Report post Posted September 25, 2005 what is TDK? where to get? Share this post Link to post Share on other sites
Mackie 0 Report post Posted September 26, 2005 (edited) TDK is the brand...same as the one for cassette tapes. U can buy these at Koba Electronics, 3rd floor People's Park Shopping Center opposite Chinatown Point. Btw, I don't recommend ferrite clamps on audio signal path.....more beneficial with power cords. Edited September 26, 2005 by Mackie Share this post Link to post Share on other sites
idkfa 0 Report post Posted September 26, 2005 I remembered seeing a thread on Head-Fi regarding clamps on headphone cables. Some guys said that they got less hiss from Shure E5c and also "better" sounding ER-4s. I did try them out but nothing significant. Maybe even nothing. Just try it yourself and "see" how it sounds then. Share this post Link to post Share on other sites
Mackie 0 Report post Posted September 27, 2005 As far as my experience goes, ferrite clamp murders dynamics if introduced onto interconnects or path where analogue/digital audio signal travels. However, some users would sacrifice it for a cleaner sound if interference is indeed an issue. Oh well, there's no harm in trying. After all, ferrite clamps are cheap. Share this post Link to post Share on other sites
Rameish 0 Report post Posted September 27, 2005 Out of curiosity I did try some TDK ferrite clamps. They do reduce dynamics. Subtle but noticeable. I did not try them on power cords cos the ones I have are too small for my power cords. They dont do wonders for me but some people have found benefits in using them just after the IEC connectors in an amp or CDP. As for me the idea of instaling clamps in amps or cdp is a worry as it will require some soldering skills to desolder the wires connected to the IEC connector and instaling the clamp and resoldering. I rather play with caps and op-amps. Share this post Link to post Share on other sites
chow 0 Report post Posted September 27, 2005 i thot ferrite clamps just click on the wire can liao? Share this post Link to post Share on other sites
