kross 0 Report post Posted November 28, 2005 hi guys, i know that this thread is available in the FAQ section but i guess i would get better chances of getting an answer if i post here. anyway, I would like to know whether I can use acetone to clean my interconnects and cans plugs? will the acetone corrode them? if not, got any other cheaper alternatives? And where to get them? what do you guys use? thanks. Quote Share this post Link to post Share on other sites
Mackie 0 Report post Posted November 29, 2005 (edited) One of the cheapest solution, literally or factually........ http://www.fairprice.com.sg/ProductDetails...D=0000000268616 (I'm not kidding.....anti-static too, great for cleaning cds too if diluted with water). For greater and long-lasting protection against corrosion and such, Pro-Gold and Deoxit. http://www.sgheadphones.net/index.php?show...484&hl=pro+gold Edited November 29, 2005 by Mackie Quote Share this post Link to post Share on other sites
kross 0 Report post Posted November 29, 2005 (edited) One of the cheapest solution, literally or factually........ http://www.fairprice.com.sg/ProductDetails...D=0000000268616 (I'm not kidding.....anti-static too, great for cleaning cds too if diluted with water). serious...can use the kiwi kleen solution?? won't corrode the golden surface?? my house have one. if can i will go and try. just spray and wipe or need to dilute with water? Edited November 29, 2005 by kross Quote Share this post Link to post Share on other sites
loop_ 0 Report post Posted November 29, 2005 anyone tried basic contact cleaner? I bought one at SLT - philips 390 CCS - most shops selling it, its a spray. Bought it due to some hardware problems, for $4++. This is the product description: "The cleaner improves electrical conductivity and reduces friction and wear. The cleaner is moisture, rust and corrossion proof." Very versatile also can use on bicycle chain etc, though prob not as versatile as the kiwi I've been spraying it on my plugs and jacks. But still too early to see if its useful. Quote Share this post Link to post Share on other sites
Mackie 0 Report post Posted November 29, 2005 serious...can use the kiwi kleen solution?? won't corrode the golden surface?? my house have one. if can i will go and try. just spray and wipe or need to dilute with water? Don't spray direct on the plug as you will be introducing moisture to an electrical connection. Spray onto lint free cloth and wipe the plugs with it. Tell me if you see a difference thereafter. Quote Share this post Link to post Share on other sites
kross 0 Report post Posted November 29, 2005 hmm..the philips cleaner looks decent to me. maybe next time i go down slt i might get one to try. Quote Share this post Link to post Share on other sites
Mackie 0 Report post Posted November 30, 2005 hmm..the philips cleaner looks decent to me. maybe next time i go down slt i might get one to try. This should be available in your friendly neighbourhood hardware store or HomeFix and the likes. Quote Share this post Link to post Share on other sites
neutralzz 0 Report post Posted November 30, 2005 acetone dissolves plastic and certain organic polymers you shouldnt use it to wipe the insulation of the interconnects itself as an organic solvent will not be able to dissolve any metal oxides on the plugs.. if you are cleaning the exterior of the interconnect i.e. insulation, use something mild like alcohol and wipe slowly, pulling through too fast will wear out the wordings if you are not careful.. happened to one of my monster cables b4.. for plugs.. use the contact cleaner.. dont brasso it or use some industrial cleaner cuz you might wear the plating out.. Quote Share this post Link to post Share on other sites
kross 0 Report post Posted December 1, 2005 ...lucky din use acetone. thanks for your info. Quote Share this post Link to post Share on other sites
jtfoo 0 Report post Posted December 1, 2005 USe Iso Propyl Alcohol. It cleans, dry fast and does not leave residual of its own. Those celaning solution would would some sort of their own residual. Quote Share this post Link to post Share on other sites
arc_sine_squared 0 Report post Posted January 6, 2006 What if it's not clean, will this effect the life of the plg or anything? Quote Share this post Link to post Share on other sites
Mackie 0 Report post Posted January 9, 2006 Corrosion will affect conductivity. Hence, sound quality may deteriorate. Conductivity is also the ruling factor behind choice of gold and rodium plating for crucial contact points along signal path. Quote Share this post Link to post Share on other sites
Peter Chew 0 Report post Posted October 12, 2014 Hi i am new to your forum but off late i was recommended the Deoxit D5 spray cleaning liquid for oxysidised RCA contact points which is available for distribution and resale in Singapore., Would appreciate whom it may concern to throw some light as to specifically the reseller outlet/ shops selling the abovesaid product . Pls respond asap to my email contact at < ckhchew2003@yahoo.com> or what's App to 6013 6374130 h/p your assistance herein is most appreciated. Best Regards - Peter Chew Quote Share this post Link to post Share on other sites
yotiao 0 Report post Posted October 13, 2014 I bought one from a shop in Adephi this year. Cannot remember the shop name. Just google it and you should be able to find it. The shop sells CD. They have the spray can or the liquid bottle. Quote Share this post Link to post Share on other sites
Peter Chew 0 Report post Posted October 20, 2014 Ok tks pal for the leads Quote Share this post Link to post Share on other sites
