N3w_Typ3
Koss KSC 35 thin cables.
2 for each signal
and how do you twist the wire?
which pair do you twist together, i.e. signal and ground twisted together or same channel twisted together?
signal and ground channel twisted
per cat5e specs isnt that?
EDIT: missed out the ground word
Edited by squalle
More important, how does it sound? I used a video cable which bpribadi recommended from SLT to recable my Senns 497 and it sounded very good compared to the before change SQ. But this wire isn't very thin but it is thinner than Cat5.
Edited by heady
Mine too, that's why I changed the cable. biggrin.gif But from memory lah. Ok, never mind if you can't recall, just curious re: the sound. I use cat5 for my DIY amps but they are short runs only.
signal and channel twisted
mm sorry still don't get it
are you meaning to say signal and ground twisted together?
is there such a specification?
oh where did you get the neutrik mini jack squalle?
jack is from LHS
cat5e has 4 pairs of wires inside. already twisted
see here: http://www.lanshack.com/make-cat5e.aspx
and here: http://pinouts.ru/data/Ethernet100BaseT4_pinout.shtml
the pairs are utilized in such that the + part of the signal uses the wire that is twisted with another wire that is connected to the - part of the signal
this will introduce more resistance towards interference I'd say
but as in why I did that for my headphones, well, more like errmm habit? laugh.gif
headphones cables should not have problem with interference, the fact being most runs are at 3m.
