Sipher 0 Report post Posted July 14, 2003 not onli in sls. anywhere also can Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 Charging lead acid must be in open area where a lot of wind. ooh... u mean there will be a smell when charging?? Even sealed lead acid requires you to charge in upright position. There will be chemical reaction during charging, it will dissipate... err... sulpuric gas if it uses suphuric acid as liquid. Share this post Link to post Share on other sites
Sipher 0 Report post Posted July 14, 2003 ooh then it's not for me Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 I plan to buy lead acid in a later stage, too much project on hand. Just finish my NUS math course. Share this post Link to post Share on other sites
Sipher 0 Report post Posted July 14, 2003 anyone knows what the diagrams/pictures found on power adaptors meant anything? Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 Which one? A bit description? Share this post Link to post Share on other sites
Sipher 0 Report post Posted July 14, 2003 got one with 2 squares. with the smaller one inside the bigger one. then got another on with a shape of a "shield" shape outside and inside 2 circles interconnecting each other hope u understand what i'm talking about Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 Not quite sure... For sure the symbol that you see may not be electrical symbol.Can use paint to draw out? Share this post Link to post Share on other sites
Sipher 0 Report post Posted July 14, 2003 one of them: Share this post Link to post Share on other sites
Sipher 0 Report post Posted July 14, 2003 i think i will try to borrow a digicam to take a picture of what i meant this wkend too lazy to draw. hehe Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 I have saw one of this before. It represent wire opening for my electronic transformer, don't know other usage for this... Share this post Link to post Share on other sites
adhoc 0 Report post Posted July 14, 2003 (edited) that symbol means a class 2 constuction instrument, which means double insulated. for all intents and purposes, it means safer. Edited July 14, 2003 by adhoc Share this post Link to post Share on other sites
jtfoo 0 Report post Posted July 14, 2003 Misconception. Seal Lead Acid are sealed and air tight. There's no outgassing. It's a variation from the car battery which is opened and dangerous. Sealed Acid battery are practically maintenance free. But the number of cycles seal lead acid battery can be charged is lesser than the car battery becoz it cannot be top up. But 6 months of usage times a hundred recharged,I'm sure that works out to be many years. Share this post Link to post Share on other sites
adhoc 0 Report post Posted July 14, 2003 if you have only 2 intersecting circles, it means a fail-safe transformer is within. which IIRC means that no matter the voltage the transformer will still work. if you have 2 intersecting circles with 2 small vertical lines at the bottom it means that the device contains a transformer with some external device that prevents short circuits in the transformer within. if you have 2 intersecting circles with a small rectangle at the bottom it means that you have a short-circuit-proof transformer. i cant remember any exact details on this. if you have a shield with 2 intersecting circles inside means that you combine all the above to get what is known as a fail safe safety isolating transformer- super safe, super reliable. some extra info: a solid line with a dashed line beneath it denotes DC a circle enclosing a vertical line which leads into 2 horizontal lines means grounded (protective earth installed) a horizontal line with a rectangle enclosing some part of it means the device contains a fuse Share this post Link to post Share on other sites
jasonhanjk 0 Report post Posted July 14, 2003 Misconception. Seal Lead Acid are sealed and air tight. There's no outgassing. It's a variation from the car battery which is opened and dangerous. Sealed Acid battery are practically maintenance free. But the number of cycles seal lead acid battery can be charged is lesser than the car battery becoz it cannot be top up. But 6 months of usage times a hundred recharged,I'm sure that works out to be many years. Some sealed lead acid required open air during charging. I had gone through some spec on it. If it is for all, i don't know... Share this post Link to post Share on other sites
