metalgear
suggest PC/software setup and settings for best sound
Hi, I'm new to this, and wanted to see how folks here are setting up their PC Audio systems to best effect:
I hope to capture details such as:
  • PC or Mac
  • software ripper name e.g. lame
  • ripping settings e.g. bitrate, file type
  • audio output settings e.g. win xp driver or ASIO
  • brand of external dac
  • optical/coax cable brand/type etc
I'm particularly interested in folks trying to setup for best sound, including lossless or near lossless.
Please also include any interesting details/options like wireless streaming or NAS data setup.
I'll post mine when I set it up !
Probably one of the more hardcore pc audio guys around. Below is my normal setup.
Hardware:
PC running a RME DIGI96/8 PAD soundcard -> Belden 1695A with Canare RCAP ->Ack! dAck! 1 -> amp
Software:
Win XP SP2
Latest foobar2000 with ASIO output.
CDs are extracted with EAC
Compression consists of mostly lossless. FLAC, wavpack and monkey's audio are the top three contenders. For lossy compression, it would be .ogg mostly.
Good luck to your setup!
For a cheap and dirty way to encode your cds, check out www.ubernet.org. I feel their uberstandard is a good compromise between quality and file size. Basically it's 192kbps VBR using EAC, encoded using lame.
Heh, I'm using PC as source as well.
Onkyo SE-90PCI -> IXOS Toslink -> Citypulse DA7.2x -> Canare L2t2s Neutrik RCA - TRS connector -> nEar 05 eXperience.
Software:
Foobar 2000 with KS
CDs extracted using EAC
Basically setup is using bit perfect from PC as source and mostly using FLACs or Wave files.
I'd played around with a few sound cards including Audigy 4 Pro, LD II+ (pre) and the XMOD. This current setup is my favorite and I seriously doubt I'll be going for any upgrade in the near future. Freaking expensive hobby if you ask me about it.
Edited by sicknature
Portable Setup
iTunes -> Macbook Black -> Total Bithead(via USB) -> Shure E500
Small yet deadly.
Home Setup
iTunes -> M-Audio Audiophile 2496 -> Generic RCA -> Harmon Kardon AV-22 Reciever ->
JBL LX440 Floorstandings
JBL Control I Bookshelfs
JBL Control Center
PSB Subsonic II
Alot bigger but alot more dangerous :grin:
Hi, care to share your impressions with the Citypulse DA7.2x?
As I'd used only a few sources before the Citypulse, what I can use as gage is pretty limited. Here goes. The Citypulse is very neutral sounding and provides quite abit of clarity. The mids is a lil harsh, not too bad actually and the bass is tight. The sound stage is wide which made the instruments separation rather obvious.
The build is rather solid. If ya using digital in, you'll be able to choose Fixed out, which uses only the DAC, or variable out, which uses it's DAC + discrete head/preamp. If ya using the Fixed out, then the volume knob and the volume buttons on the remote will be rendered useless.
It's very enjoyable listening to the Citypulse and I heard that you'll need at least 300 hours of burning in :shocking: to get the full potential out of it. It's a rather good investment if you ask me about it.
