alvin1118
DIY: AMB Lab Mini3
just done my AMB Lab Mini3 demo set :grin:
Version v2.01
Gain: 5
High performance AD8397
how it sound ? wow ~!! 1st impression, it's great! small nice handy amp! hahahah :)
running in ^_^ ~ review after few days ...
you wont be dissapointed...
I hope not, he is selling them. :))
I will hazard a guess - amb sells only v2.0, so this pcb is not from amb? Poor amb, other people selling newer versions than the designer himself. :P
Edited by heady
Hi All,
To clarify:
The AMB Lab Mini3 Kit set i have got is from a Taiwan friend, who is the authorized distributor of AMB product in Taiwan.
The different between V2.0 and V2.1 is described in AMB Lab Mini3
"October 3, 2007: All new Mini³ boards shipped are now version 2.01. This version corrects the reversed left and right channel silkscreen labels in v2.00."
Design wise it is still the same as V2.0, just the label correction :cans:
Hope it clear some doubts. :D
Regards,
Alvin
Hi All,
To clarify:
Regards,
Alvin
I'm very interested in building my own Mini3. Is there a place I can get all the parts in Singapore?
Oops, that's mud in my face. :blush:
just finished debugging & repaired a friend's mini3..sorry for keeping the mini3 with me for so so so so long. i hate exam! lol
problems are as follow:
  1. Left side no sound
  2. HIGH Voltage Output at Left Channel
after re-solder all soldering points, make sure no cold soldering or short circuit , power up and test.. well, results are the SAME :wacko: no sound no sound!! :doh:
alright, last try is to change the OPA AD8397! mini3 is well known in burning OPA. lol :bash:
SOIC OPA not easy to de-solder without proper smd remover tools..traditional method is to apply huge amount of solder on top and bottom of the SOIC, and "try" to remove it by heating up the solder...hm..i'm not good in describing, just REMOVE IT!! wahaha :rclxub:
after changing the OPA, measure OR-OL-OG to Gnd, all within recommended range. plug in my senn earbud with mp3 input~~~
wow~~it works wonder now!!! :thumbup:
Glad your Mini3 is working. Having killed so many AD8397 in my PINTs and Mini3, I found the easiest way for me is to
1. remove all the tall components near the chip.
2. insert a paper cutter blade under the chip.
3. Apply soldering iron to all 4 leads on same side at the same time by angling the iron as horizontally as possible
4. the solder on all 4 leads will melt after a few seconds. Gently pry the chip with the blade so that it bends on the 4 leads still soldered.
5. Grip the chip with a tweezer and now heat the remaining 4 legs at the same time with the iron. When the solder melts, lift the chip with the tweezer.
6. Clean the pads with solder wick.
Remember the key word is "gentle". Apply too much pressure and the solder pads on the pcb will be lifted. Hope this is helpful to those clumsy like me. :P
Edited by heady
I'm using a different method, I added a tiny ball of lead to the pads, heat the pad up to absorb the ball so more solder ends up on the pad, place the opamp in place, keep it in place with a pair of tweezers and than use the iron to press the pins down one by one. No problem with the continuity though. Not confident with the flooding method as I'm afraid of creating a short between the pins.
BTW, I desoldered C5+ and C5-, not sure how to test if it's faulty or not but when I set it to DCV 200mv, one measures 190+mv and the other measures 10+mv. Does this mean the cap is faulty?
Edited by mouz
Use the capacitance setting to measure caps. Can't use DCV to measure capacitance. At least not as I know it.
